Purple Efest IMR 26650 64A
http://vapingcheap.com/purple-efest-imr-26650-64a-12-98-usa/
Expensive for now…but expect as they ramp up production the price should drop
Sheesh! I wonder if the resistance will be lower than the Sony 2600mAh. Looks sweet!
It should be interesting to see how these turn out after they are tested. I would like to know who is making these. E-fest doesn’t make batteries that I know of. They just re-wrap them.
+1
i am interested to compare to sony vtc 26650 50a
I ordered qty 4 of 60A rated 26650's, price was good but shipping was high. Then the guy said he got the package returned because of the batteries, and it will cost me $31 more to ship FedEx -- at that point, I said no, just refund. They are rating the amps now not continuous, but in cycles, so amp specs are now all mis-leading. I was willing to take a chance with them, but I was figuring 50/50 chance.
Efest though is a pretty good brand. Guess who will have these shortly in the US, I'm thinking? Smile
Here Is what I tried ordering, but different vendor: http://www.alibaba.com/product-detail/2014-IMREN-IMR26650-60A-3600mAh-3_1857297315.html
I have been wanting to build the smallest possible 12v car jump pack (that can function longer than a few seconds so it could start it and drive a car home who’s alternator died then continued to be driven till the battery was also dead, not just crank it like I could easily build using big CAP’s). When these get cheaper it might be a good option.
I really need to finish building an external discharge rig so I can test batteries like that.
Do anyone know how these compare against the KeepPower IMR26650 3500mah and IMR26650 4200mah?
These Efest 26650 are in my testing queue.
I have this one but I need to either rebuild it with a higher current valuable ammeter/shunt or build a whole new one with an digital display, maybe something with a pot to increase load instead of individual switches. Do pot’s come in sizes that can hand that? If not what do those car battery testers use?
I should find a way to use this 700w resistor!
Here’s a few batteries I’ve tested
You can get big pots, but an electronic load is much easier.
Something like this: https://www.tindie.com/products/arachnidlabs/reload-the-simple-robust-affordable-dummy-load/
Add a few more transistors in parallel and a bigger heatsink for more power. For higher current you might also want to change the R050 resistor.
CK, is that thing saying an Efest IMR10440 will do 9A?
In my Texas Poker (avatar light) I’ve got a BLFTiny10 using this cell for 3.34A and a max 917 lumens out the front. Freakish, really…
Interested in this big fat purple cell, will have to petition Richard to acquire some with my name on a couple of sets. :slight_smile:
Yes, but literally only for 10 seconds.
Also the cell was brand new, fresh out of the box, charged up once then tested. After 5 or so cycles I expect it’ll do 10A.
60A max discharge current but higher capacity 4200mAh (We have it in stock~)
