You may fit the driver with some sanding but the problem could be with the driver retaining ring, if it’s too thick it can short the components on the edge of the driver. I have burnt several boost drivers while trying to fit them into convoy C8.
Did same thing while fitting into Convoy L2. After destroying first piece I gave it up. The outter contact ring around driver becomes too thin. Furthermore the collar ring inside the driver socket did make contact to some chip on the driver which could be additional reason of my epic fail.
If top side is covered with capton tape, nothing bad should happen.
During tightening retaining ring look out for components near the edge of the driver, it’s easy to destroy them.
