I used my Q8 the other night outside with a diffuser for cooking hot dogs on the fire. The diffuser is the Fenix AOD-L. The light was very harsh and not pleasant to be around. Does anyone have a trick to reduce the bare light bulb effect? A small lamp shade maybe? The best I could come up with was a paper plate on top.
In addition, I saw an interesting product in a TV ad this morning.
I diffuse with a flat piece of film into a taller tubular diffuser . With or without the film on the lens you can look right at the diffuser when the Q8 is on it's highest setting . Without the first film diffusion it throws more light out the end of the wand but that's not always a bad thing either .
my best luck has been using a longer tube. (otoh good ones are hard to find)
The silicone makes a nice addition . It grabs really nicely onto the top of the light .So well in fact that it's got me considering running a bead of silicone caulk around the threads of some kind of lid instead of continually searching for stuff that fits the bezels of lights
I used to like these...Shooting light thru the lid before hitting the inverted small foam container .Basically the same principle .Diffuse first before hitting the shade / secondary diffuser.
Is it harsh to look at like a bare light bulb? I like the FW3A diffuser you made but I use it mainly for lightening mode. While you’re at it the SP36 needs one too.
It’s my fav for runtime, lumens, and feels better than my Q8 in the hand. If you are patient you can get one for about $40 on Amazon with Sofirn special. I forget what the bezel measures and I don’t have it here.
