How about this? Dropped lumens to 5,000, but throw of only 400 meters is way too low. I'm just guessing they are using some sort of canned spec table - not sure row could be added or removed.
Specification:
Product name: BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
Brand: BLF
Model: Q8
Emitter Type: XP-L CREE XP-L HD V6 3D
Light temperature: 4700-5000K 4750K-5000K
Light color: Warm white Neutral White
Material: Aerospace grade aluminum alloy construction
Total Emitters: 4x
Mode: updating Smooth ramping or mode set operation
Lumens: updating
Runtime: updating
Battery Configurations: 4 x 18650 protected or unprotected button top (not included)
Working Voltage: 3-4.2v
Switch Type: Clicky Electronic switch
Switch Location: Body side of the flashlight
Peak Beam Intensity: 30000cd 50000 cd
Impact Resistant 1.2meters
Max Output: 4500lumens 5000+ lumens
Range: 200meters (max) 450+ meters (max)
Lens: Toughened ultra-clear mineral glass with anti-reflective coating
Reflector: Aluminum alloy mirror reflective cup
Waterproof: IPX-8 waterproof
Color: Black
Weight: 400g without battery
Size: 132mm x 59mm x 50mm(length x head x body diameter)
