those videos really helped me understand NarsilM. I had trouble understanding instruction stated in the manual into real world practice, feels like doing dance move by reading but visual cues made it easier.
This was discussed a long while ago so I don’t remember all the details, but parasitic drain from the LED is very low and drain from the driver was even lower. I think over a year locked out would be safe from over discharge, but if your gonna store the light the smart thing to do is lock it out by giving the battery tube a turn or take the cells out.
One of the neat features is that the switch led (as long as you don’t program it to turn off) is an easy visual way to tell if the batteries are in and power is flowing. Just twist the battery tube and when the switch led goes out, you know the power is off.
Basically the drain is not a big deal.
The battery drain on my L6 with FET and Narsil V1.2 is 0.48 milliamps or 0.00048 amps.
4 cells in parallel at 3,000 mah is 12,000 mah. 12k milliamps per hour. Let’s say the drain is 0.50 milliamps. That’s 24,000 hours which is 1,000 days which is 2.7 years.
I think the Q8 drain was closer to 0.35 milliamps so that’s over 3 years.
See, not that big a deal.
Pardon my ignorance but I am on the list but havent received a PM with a discountcode? Or did only the first 500 get one?
no no code yet.
It’s not going to be divided up by 500’s. List order does not matter. The codes will all go out to everyone at the same time. Says the Miller a few pages back.
The text and the codes are emailed to Mr.Scott and PMmed to Mr.Scott and SB
Mr.Scott has to run his magical program to assign the right codes to the right BLFers and generate the list for PMs and then they can be send.
Codes start working on Sep, 7th 10:00 am (UTC+8) and are valid for 20 days.
Single orders only! (multiple lights per order would increase shipping costs so in for more lights, create an order for each one)
Just wondering, how can shipping the same goods in separate packages be cheaper than all at once?
I’m in list to buy 4 of Q8. So I would be able to buy them in sep 7?
IDK Agro, this is the info we have :wink:
Mindaugass, yes, place orders for all 4 when you have gotten the PM
Perfect!
Just fyi for the listing on throw, the candela is 50+ kcd, or "50,000+ cd", not 30,000 as listed. That matches up well to the 450+ meters listed, and is more accurate.
"HAIII military grade hard-anodized" is mentioned in there a couple of times, and I don't think it is, should be HAII.
Tricky the ano they used
I had a really hard time to get it to change color, the type2 ano I did change the color of went fast in a couple of minutes.
The Q8 behaved the same as the Kronos X5.
=maybe it is type III?
[Like I actually care- just take my money for crying out loud ;) ]
About this , i was planning to order the 2 lights im on the list for together and opt for expedited shipping(cant wait to get the lights in my hands :smiley: ) . would that be a big no no , or is that entirely up to me.
So does that mean its 0800 am on the 7th for UTC+10 (Sydney)? Or Does that mean 12:00 pm(noon) ?
Do you mean we will get the codes before that and it wont register till that time, or thats when the codes will be sent out?
Looks like 1000 UTC+8 is 1200 (noon) UTC+10!
yes up to you.
(and Agro, the Q8 is not very light, it may be above certain cheap shping limits when there are more in a parcel)
Count down to launch
I think this is right. (Tax day is the graphic, I thought it was appropriate.)
Revised with correct time zone - probably.
Incorrect, launch is 10AM UTC+8.
From now, less than 14 hours.
