Qlite driver moon mode with star firmware.
I can’t seem to get moon mode to work with star firmware on a Qlite driver
I tried
#define MODE_MOON 3 // Can comment out to remove mode, but should be set through soldering stars
#define MODE_LOW 14 // Can comment out to remove mode
didn’t work.
So went back to code.
saw “but should be set through soldering stars”
Then soldered star 2 to ground ring and got a blank click meaning 1 mode isn’t doing anything.
So I thought maybe it means to leave ground 2 solder to ground and remove moon from code.
So i removed mode moon
//#define MODE_MOON 3 // Can comment out to remove mode, but should be set through soldering stars
#define MODE_MED 39 // Can comment out to remove mode
//#define MODE_HIGH 255 // Can comment out to remove mode
#define MODE_TURBO 255 // Can comment out to remove mode
#define MODE_TURBO_LOW 140 // Level turbo ramps down to if turbo enabled
#define TURBO_TIMEOUT 120
Didn’t work
So now I just have the 3 modes Low Med and Turbo but no blank click.
What am I doing wrong?
I wonder if adding 4 more chips would do something to the moonlight mode.
3 is probably too low.
I have had trouble with moon mode especially with XP-G2s— the XM-L2s come in and out until they get hot but after a while they must burn in —then they work fine—most likely the blank mode is not enough to light the LED—put a meter on the tail and see what that blank mode reads
Yeah that makes sense i’ll mess with upping MODE_MOON .
I had the same problem with an XPL led.
This is just practice anyway I can’t get 5 modes on a Qlite just 4 so probably won’t leave moon mode on anyway. I am just trying to learn how to do it.
Thanks!
I lose moon when the lights get hot too. It returns once the light cools.
What do you mean regarding burn in specifically?
It’s quite likely that 3 is too low. You’ll need to try several values; I’ve seen drivers get moon at anything from 1 to 9.
Also, I highly recommend using phase-correct PWM for the moon mode, since it makes the output more stable as voltage drops and it’ll light up at a lower PWM level than fast PWM.
Several of my XM-L2 lights moon mode would come in and out —then after a couple of times using the higher modes the moon works great—figured it was some sort of burn in effect
