Qlite driving XPE2
Testing an unused Qlite (Rev. A) driver with a green XPE2, on high, it went into low voltage mode after a few seconds. Thinking it may be that the LED was drawing less current than what the driver was designed for, I tried an XML2 and it does the same thing. Cells are fully charged and measure 4.1v while connected. Connections were soldered to make sure it wasn’t that. Nothing gets hot.
Did I destroy it by connecting it to the XPE2 or is it another dud?
Since it seems to work in all other modes, can it be reprogrammed so the warning cuts in at a lower voltage or is that function hardware?
Seems like a problem with the driver or a short
  • Check that the resistor values are the correct ones. They should probably be marked 1912 and 472.
  • What cell are you using?
Resistor values are good. I hit all the solder joints with the iron (except the 7135’s) and still the same. Tried different LED and cells, no change.
All my cells are Sanyo, Panasonic and Samsung, no fakes or Ultrafires, etc.
That’s 2 outta 2 bad Qlite drivers. Actually, the other one works but it flickers slightly. You need to stare at a wall to really see it so it’s still very useable.
Thanks for the help. It was worth a try. :beer:
There seems to be the odd bad Q-lite driver out there.
I had one the other day that just had nothing where moonlight should be - I had a good bridge on the 4th star, but it’s ‘nothing-low-med-high’. Not a big deal, and I have enough spares, but it did puzzle me. (They’re still my favourite driver by a long shot!)
Solved :bigsmile: … I think. The 4701 was grounding to the copper ring. I don’t know if it’s suppose to be because it’s so close but I actually scraped away part of the copper ring and it didn’t feel like it was connected. My only concern is if I just bypassed the low voltage warning.
Wait, so that is 3A to the green XP-E2? Can it handle that much?
Not for long, I fear
I’ve had it DD (4.1VF) attached to a HR-01 Plus heat pipe I had laying around. I let it run down to 3.3v then ran it on a CR3032 and a resistor down to 1.8v. This thing has a wide power band and good fuel economy.
I don’t know how many amps that is at 4.1VF but I don’t think the green is going to be pulling 3A.
Not an issue with your Qlite, you’re pairing the wrong combination of parts.
The XP-E2 green emitter has a forward voltage of 3.7Vf at 1A. Trying to push it to 3A you’re over reaching the cell.
From the Cree datasheet…
Forward voltage (@ 1000 mA, 25 °C) - green V 3.7
I wasn’t trying to get 3A. I just figured the Qlite would supply whatever the maximum current draw would be at 4.1v and, if anything, be less stressed and run cooler than driving a XML2.
I’m using a Qlite with 2 chips removed to power a little 14500 light with an XP-E2 and it works fine. It’s not a colored emitter though and has a lower Vf.
I’ve used probably 100 Qlite’s and never had the kind of issue you described. Beats me…
Richard would know what’s up, he’s used massive amounts of those little critturs!
I’m running it on an old expendable cell with an XML2 and the voltage is now below 2.6v. I think it stepped down at 2.62v but it should’ve totally cut power at 2.8v according to the specs. I guess that resistor was supposed to be connected to the copper ring. Oh well, I can still use it with primary cells.
You know exactly if actually the R2 (4701) was soldered or not, but the R2 resistor which is 4.7K has to be connected to the ground ring.
Maybe you did bypassed the low voltage reading as you say by disconnecting the R2 from the ground ring.
Now, why didn’t I think of that. I was using NANJG 101 and adding 1 chip (for running red XP-E2) to it but it’s much easier to remove them than to stack them, Only advantage is that you get that 2-3 mm of extra space with NANJG 101 which can sometimes be just what you need.
Anyway, the point is: now I know I can safely run red XP-E2 (and green XP-E2 one day when it becomes available for EU customers) with 6 x AMC driver :slight_smile:
yeah…i have too problems: one red xpe2 with a fasttech driver 5groups nanjg 8x7150 (2,8 amp) i gone try another driver +–2 amp or lower i think. (501b zoomy)
after one time the light flash or flikker
Eh, I wouldn’t use your setup with primary cells if you mean CR123A cells. That’s pretty hard on everything IMO.
When you checked the values, did you only check the markings or did you hit them with the DMM to confirm? If you reconnect the 472 resistor to GND and measure the voltage at Pin7 of the MCU, what do you get?
I’ve run both red and green with 7x of the 350mA variety and everything seemed fine. They were on Noctigons and I based the number of 7135s on djozz’s tests.
I’d run a 3v cell DD. I’m guessing 3 fresh alkaline D cells wouldn’t be too much for that driver, would it?
Yes, I checked it with a DMM. I went to solder a bridge and when I pulled away the iron, that resistor must’ve hitched a ride. It’s gone. This stuff is too small for what I have to work with.
I’d say all that’s fine. Too bad about the resistor. :~
EDIT: fine in terms of damage. I have no idea what 3v will actually provide to the emitter… maybe not much?
In darkness our rod cells are primarily used and they’re mainly sensitive to green light so a green light can and should be kept dim to see well and preserve night vision.
On the other hand, rods aren’t very sensitive to red so a red light needs to be bright enough to stimulate the cone cells which are used for seeing color.
Green light allows you to see a large area better than red because the rods are situated around the center of the eye while most of the cones are directly in the center of the eye which gives poor peripheral vision but good detail within a very narrow angle.
I would think that a combination of a bright red spot and a dim green flood would give the best of both worlds a still preserve night vision.
