hey.
i just got 2 Qlite Rev.A 7135*8 drivers from hank. along with few cree leds,
they are working fine for about 30 sec’s, tested 3 amp
changing mods is fine aswell,
but then after about 30 sec’s, the light start to flickering, fast strobe like for about 1 min, then eventually the light dies.
if i let it sit few min’s, and start again, im geting the same issue over and over again.
i wonder if its a bad batch or what can i do about this issue,
obviously i cant use this drivers like this,
hank’s replay’s was “maybe there is some back contact”
but i dont know, conntacts are very simple, positive go to midle pad, negative go to outer diameter of the driver,
i didnt even solder the stars.
the leds where tested, direct drive straight from battery works fine, no flick/strobe phenomenon…
Does the problem happen in lower modes as well? I wonder if it is a heat issue. Are the drivers soldered to the pill? And this happens with both drivers?
well its outside but the wiers are pritty short, about 5 cm, and they are thick 18 AWG silicon coated from hank aswell,
i have this same setup on my headlamp and works good even with longer wires,
btw, its a 6 pack of 18650 batteryes in parallel and are fully charged,
i know the flash worning when volt is low, its not that,
its real fast strob like then dies…
It’s strange that the same problem happens on both drivers, but I would check the PWM pin solder connection on the MCU that signals the 7135s. Touch it with the iron and reinforce it a bit. I had a driver where that joint looked good, but I was getting erratic neighbor and it went away after I touched up that joint.
so i did a reflow to the cpu but didnt work.
i think it could be that the driver think the battery voltage is too low and drop the light to firefly mod,
dont know how to fix it tho
the one i have in my headlamp is sealed so i cant see it,
i just ordered two more drivers from ali convoy store, and tbh, i dont know why i didnt do that ealyer, they cheaper by half…
i wonder if hank would refund those 2 bad Q-light’s
