This looks interesting at $45 with the coupon code, I especially like the dual switch mode change UI and the fact that strobe is hidden.
Has anyone tried/tested this yet?
Where can I see the coupon code?
In the other threads on sales from the seller, it’s: 15noorder20120614
Dual switch design would be interesting, BUT the long form factor kills it for me. :(
I use that type of lights very rarely after I started using DRY, King, and APEX. Short & fatty design just works for me.
Yeah I only noticed after posting this that it couldn’t be shortened to a 2x 18650 length. 3x 18650 is a bit too long for me as well, even with the side switch for mode changes.
The code is for $5 off, and takes it down to around $45 as specified in the OP. Whether that’s good value or not is what’s up for discussion.
It certainly does look interesting and the individual reflectors are only 2 or 3mm smaller in diameter than a p60 reflector. It should have pretty decent throw. I’ve always like the quad LED layout. Shame it’s only 18650 because with 4 XM-L sucking from 2 or 3 18650 it won’t run very long and will be hard on the cells if driven decently.
If I hadn't just spent a bunch of money on other stuff I would buy it. If nothing else in a couple of weeks I will.
I’ve really been wanting one of these…
