Question about batteries/chargers for Astrolux S1
Hello! I’m planning on buying the Astrolux S1 for edc, but I’m not sure what battery and charger I should get. I’d like to use the short tube with the light (the 18350s I think?). Charging time won’t really matter, as I’ll probably end up throwing them on the charger at night if they get low. I’d like to keep the total sub-$30 if I could, but I could always spend a bit more if it would make a big difference. Thanks!
Basically, anything from Richard (mtnelectronics.com) would probably be a good choice. Check under the “bundles” tab - I think he offers a simple charger + 18650.
HTH!
LiIons aren’t like most rechargeables which can be dropped into a charger and left there without risks. Their extra performance capacity requires extra care in charging and use- scenarios which would be safe with any other type of cell can be catastrophic with LiIons, so best to learn about them before using them.
For best performance in this light you need a high drain high quality cell. It will cost more but if treated well it will last longer and be safer than the cheaper ones.
As was told me when I got started with LiIon lights:
“Remember- cheap lights but only good cells and chargers”.
Phil
For good 18350 batteries to go with your S1, the usual suspects are high drain IMR batteries like red AW, purple Efest, black Keeppower.
Do avoid those brands that end with “fire”, like Ultrafire, Tangsfire, etc, maybe with the exception of Windyfire.
As for chargers, maybe you can start with Xtar VC4 or Nitecore D4 if you just need a simple charger.
Just be cautious and try not to leave your batteries overnight in the charger
The LiitoKala lii-100 is a popular 1-bay charger for under $5. It will handle 18650, 18350, and other sizes. I love my S1, BTW.
A decent portable charger is the Xtar MC-1, plugs into a USB so can also charge from auto converters.
Hi, can you also recommend a good 18650 battery for this light? The brand and model please for the highest output. Thank you very much!
