Been doing some reading on LED Vf and FET direct drive current. There are lots of threads here and on Reddit, but something isn’t clicking for me. Apologizes if this has been discussed ad nauseum. Here are two scenarios (two popular flashlights with FET that I own) that I’m trying to wrap my head around.
Scenario #1 (Emisar D4V2 w/ SST20 4000K): Four parallel LEDs capable of drawing 5A+ each for a total of 20A from a 30Q or VTC6 rated for 15A. Is LED thermal regulation all that is keeping the cell from being in the overcurrent state for too long? Repeated turbo activations over time would result in a lot of strain on the cell, wouldn’t it? And I know folks here stop charging their cells at 4.0V or lower to try to eek out every last charge cycle that they can, but I’ve never heard anyone mentioning overcurrent discharge straining the cell in a D4V2.
Scenario #2 (Sofirn SP36 BLF w/ LH351D 5000K): Four parallel LEDs capable of drawing 8A+ each for a total of 32A, but this time pulling from three cells. Current draw per cell is 32A / 3 = 10.67A, well within the current limit of the 30Q or VTC6. Here, the limiting factor will certainly be LED thermal regulation, so this seems slightly more acceptable. If you use the stock Sofirn cells, we’re (probably) back to scenario #1 with cell overcurrent.
Now that I write this all down, I’m not sure where I wanted to go with this, except to say, I’d like to swap the SP36 LH351Ds for 519As. I’ve found two folks on Reddit that have done it. But I’ve also read that the SP36’s turbo would burn out the 519As, because of their lower Vf, allowing for more current to be drawn, than with the LH351Ds. This is where I get stuck. I don’t understand how one would interpret that bit of information from the graph in the Reddit post I linked above. I understand that if voltage goes down, current must go up, all else being equal. I understand Ohm’s Law (or do I?). lol but how would one “simply understand” (from that graph) that the Vf is too low for the 519As to support FET operation? How low is too low?
If you made it this far, thanks for reading!
