Question about MCPCB
Can anyone tell me what this circled thing is on the mcpcb. The positive tab of the mcpcb didn’t have continuity to the positive side of the LED unless I bridged this with solder. Now I’m wondering what its function is.
I googled the image I see this may be a surface mount resistor. This is on a streamlight polystinger. I removed the mcpcb and reflowed a Nichia 519a onto it. When I checked to make sure the LED was mounted correctly I wasn’t getting continuity. So I bridged this with a solder blob and everything worked.
I’m new to all this. I suppose I bypassed a safety feature for the LED. But I would have just put a newer mcpcb on which doesn’t have a resistor. Do you think I’m ok, or will I burn the LED up?
Thanks.
Could be a diode, lol…if bridging/jumping it allowed current flow, I’m convinced it was a diode…
Anothee thing, did you check for continuity on that component? Does it read open one way and closed the other way?
I used my DMM to check from the positive contact on the mcpcb to the negative. This usually dimly lights the LED for me. I wasn’t getting that so checked for continuity between the positive pad and positive’bar’ the LED sits on, and same with the negative side. I had continuity on the negative side but not the positive. I had continuity from the positive pad to the one side of this component. When I bridged it I had continuity all the way to the LED. I’m new to this and didn’t know there would be any components on the mcpcb itself.
This is most likely a 0 Ohm Resistor aka a jumper.
I am unable to read the numbers on it so I’m not 100% sure.
Really need a higher quality photo to identify any markings.
Is there any way this could be a PTC resistor as some kind of crude thermal protection?
Basically a fuse?
Not without additional wires
A 0 Ohm resistor would just have a Zero on it, here we see more numbers than one.
A google search of the numbers and letters on the MCPCB found out, that the light is a “Streamlight Stinger LED HL” or “HPL” - at least the LED board looks similar:
At least the HPL runs with NiMH cells - so maybe it really is just a resistor?
At this price (over 150:money_mouth_face: I would assume LiIon and some kind of driver…
