Question about SRK driver
Hello i have cheap china 7 led flashlight aka SRK flashlight, i plan to replace emiters, and modify cooling , for new emiters, but i have question about this driver, its look like simple fet driver, so anyone can tell me that this drived dont have any current limit? when i replace led i need about 10A for deliver to 7 led, i will use high drain 18650x4 so battery will not limit current, so driver will be or it will handle as much as battery can output?
There is no current limiting resistor, see the big zig-zag trace on the board? That effective limits current.
You need to short the FET’s right leg directly to ground to bypass the zig-zagging trace.
thank You , i didnt see it ;( btw, there is ay way then to limit current above let say 10A? like new firmware or something ?
