Question about tail cap current
I have seen two modifications that people usually do to reduce resistance and increase the current to the LED: adding copper to the spings, and using wires with larger diameter (smaller gauge). When I measure the current at the tail cap should not that be the same current that flows through the entire flashlight? I’d thought that the flashlight can be imagined as a system in series, so whatever current is measured at the tail cap should be the same at the LED, right?
It is the entire current passing through the light, but it is not the current passing through the LED. Remember that there is resistance between the body and LED (springs, driver, wires, connection points, etc.)
Someone will correct me if I’m wrong here… But, what you are measuring at the tailcap is the amount of current the driver is drawing. The drivers aren’t 100% efficient though so some of that energy will be wasted as heat etc. Which is why you always hear about “driver losses”
I think the only time tailcap current is the same as emitter current is when it’s direct drive.
Even with "direct drive" you still have losses through the springs, connection points, and even wire. Of course we can minimize these to an extent that they affect the output and measurements very little, making that resistance practically nonexistent, but it is always there.
How do you measure how much is going to the emitter? Resistance Equals tail cap minus emitter?
Resistance causes voltage drops. Spring mods minimize voltage drops and preserve available voltage for dropping across the led. Tail cap current is all the current being supplied by the battery but not all of this goes to the led. A small amount leaks through the voltage divider. A small amount leaks through a Zener mod if there is one. And a measurable but still tiny fraction of led current is used by the mcu to run and provide the pwm signal to either the 7135’s or FET. Buck and boost drivers convert battery power to led power through the use of a switching IC and a coil. Sort of like a transformer does for AC current.
And all those leaks, is that a measurable amount of current? I always assumed that if the driver does not buck or boost the voltage, the current measured at the tail is exactly the current at the led...
BTW, I measured a number of tail sections of various lights tonight. I clamped my power supply to the tip of the tail spring and the other pole to the ring that makes contact to the body, pumped 6.0A through the tail and measured the voltage. I did measure springs and switches separately before, but measuring the whole assembly is quite sobering too : most stock tail sections show a voltage drop of 400-500 mV (two springs collapsed at current-controlled 6A, one was the tail spring of a Eagle Eye X2), if the tail spring was replaced by a copper alloy spring, it went down to 150-200mV, with a copper braided spring I still measured 100mV. There's apparantly some extra resistance in the traces on the tail boards.
Please explain how a buck or boost converter is related to an AC transformer, beyond the fact that they both use magnetic fields.
Edit: please don't take this as a personal attack; I'm just curious where you are coming from here, because I don't see the connection beyond magnetics.
No worries, it’s simply how I wrap my head around the results. The two current paths in a transformer don’t physically touch, the windings of one induce current in the other proportional to the ratio of the windings. I’m not saying that boost and buck drivers work exactly or even remotely this way but that the current from the battery isn’t the same as the current through the led so tail cap measurements aren’t indicative of led current. I just find it convenient to think of buck and boost driver output as being similar in result to an AC transformer even though they don’t work the same.
Djozz, you can measure both the voltage drop across the mcu and the current through it (pull the input diode). Harder to measure the current through the voltage divider but pretty easy to calculate(it’s very small but not zero). LEDs are voltage sensitive so any extraneous voltage drop will lower the current in any direct drive set up. Springs, switches, FET, threaded connections and even the length of the host all add resistance and hence voltage drops. The mcu and voltage divider are in parallel with the led so the maximum current the cell can provide is lessened by the amounts they consume. The amount of voltage drop is directly proportional to the current as determined by Ohm’s law V= I x R. With a buck driver any power losses due to resistance show up as loss of run time in regulation when lack of overhead voltage causes the driver to fall out of regulation.
Anything in series with the circuitry from battery to led can voltage drop what it likes but still the current at the battery is the same as through the led. It is just the stuff that is parallel to the leds that makes the led current go down compared to the tailcurrent. Anything at mA level will not matter, so what component eats more than 50mA and be significant?
