I recently built a light for a friend using This driver . I wanted a light that would run on two CR123 primaries, and the driver is good for 6V. I added two chips to bring it up to 1.4A.
I know that when measuring current from two 4.2V cells the tail reading should be doubled, but does that apply to two 3V cells as well?
I’m getting a reading of 1.4A whether I use one 4.2V cell, or two 3V cells.
Can someone set me straight?
When taking a tail reading with 2 x 4.2V cells the reading must be doubled to get the correct current reading. A 3A driver with two 4.2V cells would give a tail reading of 1.5A.
Shouldn’t that tail reading of 1.4A driver with 2 x 3V cells give me a reading of .700A?
Does this law only apply when using 8V as compared to 6V?
you using linear driver, it will put out same current regardless of voltage. it turns extra voltage into heat.
you would see current that cells see (tailcap), change if it was switching\impulse driver. , but with linear driver, current at led, and cells always the same.
I built a second light with the exact same 1.4A driver. With one 4.2V cell I get a solid 1.4A tail reading.
With two 3V CR123 primaries I get an initial reading of 1.4A that steadily drops I.4-1.3-1.2—–1.1…etc.
When I remove the DMM leads for a second and then replace them, the reading starts back at 1.4A again and starts dropping.
What is causing this?
