Question on mod'ed LF head
I filed down an 18mm MCPCB with Samsung LH351D to fit my LF 1" head. I used the 5A Convoy driver from an S2+ (12 group). Here’s my issue…
When I swapped in a LH351D for an SST40 (5A Convoy Driver) on an S2+, the brightness was a hair less (compared to my other SST40 S2+ w/5A). However, with the filed down MCPCB w/ LH351D and the same 5A driver, I’m getting significantly less output.
The LF head is a bit larger, and the reflector creates a tighter/brighter hot spot than the S2+ (in theory). However, subjectively, it seems like I’m getting significantly less lumens. If the S2+ is theoretically getting around 1300-1500 lumens, it seems like the LF head is getting maybe 600-800 lumens… this is my guess. I’ve tried the head with a SF 1S body with McClicky switch and Malkoff bodies for a single 16340 and 14500.
  1. I am able to change mode groups with the LF setup, and they work fine, e.g. 100/20/1.
  2. I have tried new batteries rated for higher amps (Vapcell H10 14500, and Vapcell 16340 T6 and Efest IMR 16340 700 mAh V2. I don’t have an 18650 body that fits the LF E-series head.
  3. The LED is centered and sitting far enough into the reflector.
The LH351D LED doesn’t look damaged, although I might have scratched a tiny side of the LED dome while filing down the MCPCB.
Is there a chance that there could be a short if the modes are working perfectly?
Is there a chance the small scratch on the reflector could have such a significant reduction in output?
Could it be that the overall resistance is significantly higher than the convoy setup? I haven’t tested tail-cap amps yet.
Unfortunately, I don’t have a lot of free time, so I’m asking to hopefully not spend time on potential fixes if more experienced people might have a better grasp of the issue and can direct me to the higher probability issues for repair or modification.
I’m currently using this head for my EDC, and often months will go by before I have enough free time to dive into taking the head apart, swapping components, re-soldering, etc… although maybe sleep is overrated. :stuck_out_tongue:
