This is an important driver test, but rarely found. Usually cheap drivers have lame firmware with programmed too early stepdowns. Low Vf leds can keep power at low voltage but driver usually programmed for High Vf leds … Thin wires, spring , PCB tracing, high resistance mosfets does not help too. At worst case you can get same performance as good linear driver have or even worse.
