Are these any good for modding at all? I was looking at one on DX that had 4x XM-Ls, and thought it might be okay for a 2S2P LED arrangement.
If it’s any decent, I thought it might be good for a XM-L2 and DD driver swap.
The TR-3T6 is its own pattern/style apart from the C8, the C8 is a 1x18650, single emitter light with a 42mm reflector.
The 3T6 is a very moddable design. Toss in some good batteries and a zener-FET driver and they can be monsters in their own right. Even stock, the genuine Trustfire lights are pretty flexible, they can take any battery combination you can think of that gives the driver more than 5 volts and fits in the battery tube; 4xAA, 2-3x18650, 2-4x18500, 3-6xcr123, 3x16340/18350
So I’m reading about forward voltages and all that, and I realize I’ve been thinking about LEDs here as if they were static resistors.
I come from the vaping area where it’s easy to calculate it all out - V, I, and R and those values don’t change for the purpose of figuring out power, etc. 1V through 1Ohm pushes 1A for 1W.
What’s I’m dumb about is: I have 1 XM-L, I drive it directly with 4.2V (from an 18650, etc.) and it’s okay with proper thermal management, etc. But if I then take that same XM-L and drive it with 8.4V from 2 cells wired serially, the LED won’t live long at all.
But will it be okay if I then take those two cells wired for 8.4V and run them through 2 XM-Ls also wired serially?
I thought it was that simple, but sometimes you know what you know, and there are known unknowns, and there are unknown unknowns. (Thanks Mr. Rumsfeld!)
Yes, you would be fine running them 2S2P if you had a 4 led host. I actually kind of like your idea, but some of these multi-emitter lights have dubious quality.
Looks to be decently well-built, but I’d want to replace the XM-Ls. The concern I have is how close the LEDs are - might make fitting a 16mm Noctigon difficult. Same company that’s making the D80-SE in the group buy.
I’d go with this one 2-26650 cells split up for 3-4 leds should give better than average out put and run time. The leds might also be mounted on only one board so you could reflow the other leds onto it.
I was thinking 3x XHP50s… Turbo wouldn’t last forever, but the heatsinking’s decent and with a BLF17DD you’d have usable lower modes… Moonlight for days!
