I know this has probably been discussed, but i am having a hard time finding a answer. If I run a 17MM FET Driver with 3 7A3 tint XP-L leds, would i be better off running series or parallel on the MCPCB for the leds?also say i was running a 7135x12 Qlite driver, parallel would be like 1.5a per led right? how many amps would the emitters get in series?
If you are running a single cell with the emitters in series you will get 0 amps. You are correct on the parallel current distribution. Does that answer your question?
it takes alot to bother me lol. and yeah i was thinking that after i logged off. had me confused. if you can run 15 XM-L emitters off 4S batteries, i though 2S would run 3. i guess i will run parallel
3s batteries would run 3 in series though… i could run 3 18350s in a Solarforce L2 host…… i have a extension tube for a single 18350 plus it will hold 2 in place of a 18650…….
Whether you wire them in parallel with 1 cell, or in series with 3 cells the emitters themselves will still see the same voltage. I would just go parallel for simplicity’s sake.
