I came up with a figure of ~26 hours but I am not sure if that is right.
I have mostly 2800 MaH batteries
You know that they’re all going to say that you need to do some testing.
Asking online is much faster, also if my math is right I can estimate 3400 MaH.
Search for my run time tests. Basically a long time.
I don’t recall seeing any testing on low. I would assume that the losses will add up (typical) and give you less runtime than the theoretical value.
Good Day,
Have a look at:
BLF X6-SE: run time tests (By Rod911)
Best Regards,
George
Definitely not just 26 hours. I will go back and look, but I think it is 5 days.
with a clock in the picture. Or do I mean a calendar? Both!
Somewhere approximating a week on 3400mAh cells ![]()
Current draw approximately 11mA when I measured mine.
Do the maths for whatever cell you are using.
