I’m swapping out XP-G2’s for XP-G3’S on a quad board on my BT40S bike light (2S2P arrangement). The “dot” (polarity marking) is the same between both emitters, correct? Reason I ask, I reflowed the XP-G3s with the dot in the same location, reassembled the light and none of the emitters light up. PCB wiring showing 8.3v. I’m guessing I just didn’t have a good connection on one or more of the emitters after reflow (i.e. not enough solder on the pads). I’m in the middle of removing all emitters, adding solder to the pads, and reflowing again. I had to stop for the day and not sure when I’ll have 10 minutes to myself to get back to this again.
Oh, and IIRC, on my 1st BT40S I think the Nichia 219C’s I used had the polarity “dot” reversed from the XP-G2s.
Take a DMM while the star is hot and test the emitters
The thing when I eflowing without a solder mask stencil you add a lot more solder than needed then tap on the dome fast to push out all what is too much
This way you end up on all 3 pads with enough solder
On the pad side there is always an arrow showing the anode
If you look on the bottom of the emitter you will see two lines. One line has a triangle. The one with the triangle pointing toward the other line is the + and the other is the -. So the plus side has the arrow but it points to the neg.
I hope someone with more experience chimes in but I messed around with some xp-g3s and found that the polarity is opposite of the xp-g2 or xm-l2. I was in a similar situation where I couldn’t get a led board with an xp-g3 to light up. I just figured I made a rookie mistake so I redid the reflow a bunch of times with no luck. Then I searched the datasheet and the forum and could find no mention of switched polarity. After great frustration I figured might as well try flipping the xp-g3 around and it worked!
Just now I compared the underside of an xp-g2 to an xp-g3 as Lexel mentioned and when I lined up the leds by the dot on the front then flipped them around the arrow points in opposite directions.
Yes. Black dot does not mark polarity. It marks relative position only. The underside is what will show the polarity. It is as I mentioned before. The undemarkings on the g2 and G3 are the same. The “arrow” points to negative or cathode.
Thanks y’all. I’ll take a closer look at the undersides of both the XP-G2 and XP-G3’s when I get back to it. I swore those black dots were a polarity marking! Maybe I got lucky when I reflowed the Nichias and held the dots from the XP-G2’s!
Just got a couple minutes to compare the two emitters. Those black dots are opposite on the XP-G3’s so I had every emitter mounted backwards! Thanks for the help everyone!
So I corrected the initial issue, but I’m still having a lot of trouble with these emitters! I didn’t notice it at first, but by the time I got around to getting sphere measurements I noticed that two of the emitters were extremely dim. This is a quad board running 2S2P. Current measurements at battery pack (this is a bike light) & at emitters hold pretty steady where I expect them. Here’s a pic (click to enlarge):
I’m having trouble with the very top emitter and the one on the left side (these 2 are in series). When I accessed the pcb after removing the bezel I noticed that when I slightly pressed the left emitter that they lit up bright (then I accidentally dedomed the emitter and so reflowed on a new one). After reflowing the new one I thought it was working ok, went to take sphere measurements and saw it was flickering a lot and those same 2 emitters went dim again. So I removed both emitters and removed solder (on the bottom of one emitter it appeared solder was shorting from one of the side pads to the center pad), cleaned up the pads on the pcb (thinking maybe I had too much solder), reflowed again, and same thing - flickering a lot until dim again!
Any ideas? It wouldn’t be caused by me trying to drive them backwards initially, would it (why would the other two work fine)? Could it be a bad pcb? Could it be heat related, though it occurs almost instantly from cold turn-on? Could it be a bad thermal connection from the center of the emitter to pcb?
This is frustrating! My first BT40S was modded with 4 Nichia 219C’s and that reflow & mod went flawless (and that was my first quad reflow). I’m about to get 4 10mm SinkPads to drop in this light, but I’d really like to avoid doing that.
EDIT - Just thought of another detail. I modded this light in stages taking measurements at each stage. At the previous stage I swapped the stock XP-G2’s to these XP-G3’s but hadn’t boosted the driver yet. At that stage sphere measurements & beam shots seem to indicate the emitters were working (unless the two XP-G3’s were in fact producing higher output than the 4 stock XP-G2’s). The next (and last) stage was boosting the driver which is where this issue seems to have appeared, though like I said driver output is as expected and two of the emitters are running normal (and I’m measuring around 1200 lumens with those two bright and the other 2 dim).
Link to the MTBR post where I posted details and pics on the driver mod (and if you scroll up on that page you’ll see posts about the emitter swap and beamshots).
