quick story of my kind of luck
so i got a call from work bringing me back from layoff the other day, and today i had an appointment at 8:30 am to fill out paper work and a medical exam so i can start work next tuesday.
the day started out good. woke up to my alarm right off. got up made a cup of coffee and browsed BLF a little before my shower. had a PM from a very generous BLFer, didnt feel right about accepting it, but did under 1 condition :bigsmile:
good day so far
then i go out start my car and let it defrost. it was a cold morning, about 2f. scraped the ice off the windshield, and went to put some gas in. after fill up i got about 3 miles from my house and the high coolant temp light came on. pulled over and checked, and yes steam was coming out my over fill tank. took me about 35 mins to make it home from 3 miles away just to keep it from being dangerously overheated.
so yeah. thats my luck. coldest day of the year, and my car decides it wants to over heat
and i did make it to my appointment, half hour late. but i did make it, and i do start back up tuesday 8)
Congrats on the renewed employment! Not a good time to be out of work...
So why's the car overheating? Low coolant level? I had a car with a bad head gasket; I always carried a several gallons of water in the trunk and had to stop every 10 minutes to refill... I hated being a broke college student...
Dang - did your water pump take a dump?
Congrats on the job !!!
My fuel pump is going out so I can relate to the frustration.
i think its a thermostat stuck closed. its usually stuck open, but i let it slide because im laid off. hope its not a water pump though.
i just thought the fact its the coldest ive seen this year and thats the day my car decides to overheat lol…
Is your car Australian
nope, its a mexican made german car haha… its a VW cabrio
Congrats on the job. As for your car it could even be something as simple as old anti-freeze/coolant. Without proper coolant it can overheat regardless of how cold it is. Was your heater working properly? If not then it’s also a good chance that your coolant/anti-freeze needs to be changed.
Well anyway, good luck.
Hopefully it’s as simple as a cracked radiator hose or faulty thermostat. $30 and you can DIY it yourself to save a few $.
I have a Mexican made VW too! 96 GTI. Selling it before the repair bills start to pile up as its got over ~190k (120 miles)
that really sucks… at least you are heading back to work… so if it is something that you have to get a shop to repair like a water pump etc you will have some funds coming in soon
best of luck
its not a cracked hose and theres still plenty of coolant in it, but it looks nasty. if it was a cracked hose there would have been coolant all over, but there was just a little from the overfill
mines got like 125k miles, and i just got it to commute to work. cheapest 4 banger 5 speed i could find with decent miles.
I got my first car at 16 and didn’t know about anti-freeze. First real cold morning on the way to high school the car over heated. I remember talking about it and thought it was so ironic that it should over heat on a COLD day. My friends clued me in.
that it by chance? second link from a google search lol
i have it parked at a gas station about a mile away because my girlfriend got ahold of me and i had her come get me with the xterra… its warmed up to about 12f… lol.
when she gets home from her appointment i will go up and drive it home, and let it idle in the driveway and see if it over heats again. if it doesnt ill drive it out to my dads about an hour away and flush the coolant and change the thermostat. im just hoping the previous owner didnt just use water and it froze and cracked my block. dont got the $$$$ for a new engine in that thing
Glad you got the call back to work :slight_smile:
Hope it’s a cheap fix and you can do the repair yourself.
Did it have enough anti-freeze mixed in coolant?
He was from CT, but that’s not me. In your case, i would think that you have a stuck thermostat, or a cylinder head gasket leak (can leak to the oil or the combustion chamber). If it leaks to the combustion chamber then the cooling system can be over pressurized. In the past, I have had them go both ways. A stuck thermostat is not all that uncommon, and it seems to happen more often nowadays that in years past. (I was 16 in 1966)
Definitely do the stat and coolant, a head gaskets not so bad on a golf (rabbit over there I think) is it 8v or 16v?
I can also have an ask around my gti mates if you get stuck? See if there’s anything else pops up as a common cause.
Well, I don’t like to paint it all black. From the details you wrote about, my humble guess is: I hope I’m wrong, but it could be the block is cracked.
More likely if it is a Maine car, it had anti-freeze in it already. Most people up that far north know better than to not run anti-freeze. Stuck thremostats happen a lot in the north. I grew up in the cold and lived in it for 25+ years. I've never had one stick in warmer weather, but I always ran into it up north. The fact that it's got a 125K would suggest it had anti-freeze. If the previous owner had always run water, it would never made it to 125K
Fingers crossed for the most common problem and easiest fix. Good to hear you are back to work.
