Quick Test - Cheap 2x1A 18650 eBay Charger
Hi all,
This is a very quick test to see what my cheap 18650 chargers are sending into the batteries. I did this after I noticed that the charging time is way too long than what 1A should be.
First, let’s check the voltage.
A nice 4.23v, good for topping up the batteries. Now, the real test, current. It claims 2x1A. Or is that 1A divided by 2? :stuck_out_tongue:
Aaaand… i honestly don’t know why I was expecting anything else:
So, only a quarter of what it claims. The strange thing is that the current stays the same even if only one battery is plugged in. And I don’t think this has individual output per bank.
I don’t really mind this because this is a very steady current to soft-charge my units, it would take about 10-12h for one of those 2400mAh Trustfires. I’m never in a hurry to charge them, because I already have backups. :bigsmile: I just thought that some would consider these when buying one. They range to about $3-5 on eBay.
Otherwise, the build quality is ok for this price, the batteries fit nicely and they seem securely clamped once in.
Thanks for reporting your testing.
Are you confident you were in the CC portion of the charging cycle? Current decreases considerably during the CV portion of the charging cycle.
Thanks for pointing that out! Let me completely discharge one set and see how it handles them then.
My observations of ~10-12h of charge time indicate that this current is somewhat the same. 2400mAh(real) / 10h = 240mA
Nevertheless I will come back with a new set of measurements to check what you pointed out.
Makes sense with the charge time. I missed that in your OP. I've been skimming too much lately.
thanks!
do we have to calculate with “China Ampere” in the future?
Well, I really thought the amps were real when I bought it. There are a lot of chinese nice deals out there, especially in electronics. Step-up / Step-down modules, nice quality and at giveaway prices… I even have a 220v > 12v 2A converter that I drew 2.5A out of. Thanks god these are cheap and you can say “lesson learned” without having to stop eating for a week.
Should I even test my even cheaper, 600mA charger? :frowning:
go for it!
I have one and peeked into the gut. This cheap charger actually have individual charging circuit.
But your charging amp of 0.24A is kinda low. Is that from the start of charge - when your battery voltage is low?
I have one of these chargers. I just put a drained cell in it and the charge current is 700ma.
I’m draining another battery now to see if it can maintain 700ma each into 2 cells.
Put a battery in slot 1, charge current into the battery = 700ma.
Put a second battery in slot 2, charge current of battery one goes negative! Battery 1 is discharging into battery 2.
This charger just went in the garbage.
@Pulsar13 I emptied out a pair of the same genuine Trustfire 2400mAh and put them to charge. Initial current when they were completely dried out, 0.4A… and dropping rapidly! Like 5mA/second. So I said hey, let’s measure again in ~5mins after it’s stabilized.
Well, surprize surprize!
Or not.
0.24A again in both slots.
There must be different kind of chargers out there, because mine will never ever put out 0.7A like TexasToasted one does… or used to? :laughing:
At least mine does charge them individually and steady, without discharging one into the other.
M4D M4X I will! As soon as I get a bit of breathing time I’ll put them to the test. And guess what, I found an even cheaper, one slot charger that claims 320mA @ 3.6V. One of these universal “charge’em all” thingies. This will be fun.
Looking closer at mine, it looks exactly the same, except mine has a different model number- HXY-042v2000a
It still has the DX sticker on it- 3006105
Opened it up and took a look inside. Nothing obviously bad, but the AC power is wired directly to a set of 4 diodes in a bridge rectifier. There is a spot labeled on the board for an input fuse, but they saved the penny for a fuse and bypassed it.
I didn’t get it from DX, just got the cheapest of those models from eBay. So this confirms it, there are different chargers, all looking the same.
One that has a snail’s pace charging rate, one that discharges one battery into another and… who knows how others perform, maybe someone else will tell us about theirs.
Pulsar13, could you please check your model number and if you can, maybe measure the currents in both slots?
I’ve got a similar cheapie charger testing atm.
Stated charge - 650mA
Actual:
3.9v cells charging:
1 cell - 350mA
2 cell - 175mA
107*F focused in a single spot on the back of the charger after 25minutes, cells are not receiving much of that ~75F in a 68F room.
I have an exact cheapie from another bundle that looks like the one you guys have, but I haven’t tested it.
Mine’s from myled from their $0 sale (pay shipping only). I think it was $1.88 or something.
And yes, after checking, it’s different. The label shows:
model “SKL C-0420-1000”.
Input AC 100-240V 500mA max.
Output 4.2V 1A * 2.
I’ll try to get amperage later.
