Ran across these Soshine 5500mAh protected 26650's and they seem pretty legit so far.
I picked up 4 of these Soshine 5500mAh 26650 protected button top batteries at DX Soul:
They took a month to arrive (after they got lost once) but they did arrive in a nice plastic battery case and each was individually shrink wrapped. I took 2 out and put them in my BT-C3400 V2.2 analyzer and performed a “charge test” on them where they are first fully charged, measured discharge, and then charged again. I have pics but not sure how to upload them. Charging and Discharging @ 1A, they measured 5288mAh and 5313mAh for the 2 batteries. I am in the process of testing the other 2 (it takes a while). They are 68mm long, so should fit in just about any 26650 setup. They have a max continuous discharge rate of 4A, so won’t work in some of the higher output setups. BTW, they do state a min of 5300mAh on the battery. As soon as the other 2 batteries finish, I will post their mAh.
Dr_dx
I have been waiting for a month or so for mine two x 2 pcs of the same battery. They was send out one time, but got returned because the custom in China, so they had to send it with surface mail, and that can take for ever.
But good to see that they actually work, and have the correct rating.
I got 2 pcs of TrustFire 5000mAh (the flame type) and they checked out they also, both around 5000mAh. So got a couple more.
Okay the other 2 have finished. So for the 4 new batteries Charging & Discharging @ 1A, they measured:
5288mAh
5313mAh
5275mAh
5243mAh
on my BT-C3400 v2.2 in “charge test” mode. That puts actual capacity within 1% of claimed minimum capacity (batteries claim 5300mAh minimum).
NOTE: The web page states a max discharge rate of 5A, but the batteries say 4A on them. Also the web page states a length of 68.5mm, whereas I measured mine at 68mm.
Tested 3 of 4 batteries on two of my LiitoKala Lii500 chargers, with a charge - discharge - charge @1A (like the BT-C3400 charger test). My results was not so good like yours:
4786mAh
4726mAh
4868mAh
It’s the same batteries from DX.com (paid $38.x for 4 pcs).
Strange that the numbers is so different, but it can’t be anything wrong with my chargers since two gives me around the same numbers. Will run a new test tomorrow, when they are charged up again.
Edit: Got better results on some TrustFire 5000mAh batteries on the same chargers:
4985mAh
5140mAh
then my test of the 4 latest (and last) Soshine 5500mAh batteries was over, and the trend is the same as with the first four. I have tested two and two in each charger @1A charging - discharging . charging
4924
4777
5047
4684
So still god value for my money, but I don’t understand why I get low numbers on my batteries, contra the Opus
