Raptor series buck DC-DC converters
Anyone want to take a poke at this?
4.5-14Vin 0.59-6Vout 10A
http://www.digikey.com/product-search/en?keywords=NQR010A0X4Z
Bigger brother but might not fit in a host unless it’s a HUGE multi-emitter host w/ ALOT of driver space…but at 20A…boy howdy!
http://www.digikey.com/product-search/en?KeyWords=NSR020A0X43Z
Heck…here is the whole series…up to 60A!!!
http://www.digikey.com/product-search/en?FV=ffec23d7
For $8 I’ll add a few to my next DK order, you know I’ll have to trace the board and remake it in pretty purple with my choice of MCU (10F322).
:smiley: If it has modes…let me know how much man :slight_smile:
How can they take that much heat just by stitting in the air and FR4 board? the small one at 60W.
I saw being mentioned about "Output Voltage Programming " from 0.59 to 6V So no constant current mode output?
Thats funny. I was just looking at those last night.
EDIT: I was unsure if we could use pwm for modes or we needed to use something more exotic that varies resistance (Trimpot) in electronic form. Or find a host that takes a trimpot of course.
You can use a trimpot for adjustable volts, or a fixed on the TRIM pin to ground for a constant voltage (I stumbled across these when investigating vaping box mods)
Feed the output thru a MOSFET BLF direct drive and voila
I did not look it over properly. But I was unsure if the unit will not self destruct if output is not connected or PWMéd. Some stuff does not like that. At all!
EDIT: I was also aware that a trimpot would work. But perhaps we should look at building an electronic trimpot that changes a pwm signal into a resistance. That would be the route I would consider. If I was to consider anything.
Dang …… been sitting on a big red pt121 and looking for a possible driver. Not driver savvy but would it be possible to mod a 40A to 30A? Thought about using a HID 85W for a host. Been running the big green PT120 DD in a 4D maglite with NiMH.
digital pot?
http://www.mouser.com/Semiconductors/Digital-Potentiometer-ICs/\_/N-4c498
I understand they are very popular in Colorado and Washington state these days… :party:
That’s funny too because I just found out that our club has a very similar driver, the PTH08T210W from TI.
Here’s the datasheet. Unfortunately it’s a little too complicated for my needs.
@ warhawk: Yes exactly. Though a few of those you linked are quite large physically. Anyhow I have all too much on my plate right now to look into it for any length of time.
