RAYUS C01 NICHIA 219 B11
Brand and Model: RAYUS C01
LED: 219 NICHIA B11
Modes: One. 29 lumens, RUNTIME 3h 40min.
Compatible Batteries: 1.5V AAA alkaline or Ni-Mh (not allowed Li-Ion 10440 3.7V)
Type and position switch: Twisty (screwing-unscrewing)
Date on which acquired Lantern: Received 10/23/2014
Links: Manufacturer Web http://www.rayuslight.com/category.aspx?NodeID=50
Length / width / weight: 68 x 14 mm, (2,68 x 0,55 inch), 13g (without battery)
Material: Anodized aluminum type III (aircraft grade)
The sample has been given by the manufacturer for the review.
Above all, I hope you excuse my poor English, based primarily on google translation tool
I have received this flashlight through the mediation of “Reviews de linternas” http://reviewsdelinternas.blogspot.com.es/ and the BLF user UPZ. The brand Rayus still has very few models as it is starting to walk in the led flashlight world, but intends gain a place in the segment of premium brands. This new brand has been formed by a group of engineers and marketers with extensive experience in the sector, including people that are responsible for some successes in Fenix, Rofis and other top brands, with quality construction and electronics similar to brands like Fenix. One of his first tricks is the release of the C01, a keychain flashlight with the same philosophy that the successful old Fenix E05, with XP-E R2 LED and 27 lumens for about 2 hours and 50 minutes.
The performance of this Rayus C01 is very similar to that old Fenix E05; with an XP-G2 R5 in the cool white version and a NICHIA 219 B11 in the neutral tint, announcing a runtime of 4h. and 3h 40 min, respectively. I will examine now the neutral white version, with a led Nichia.
Now we can see this flashlight on the website of IS ($ 14.99), both versions at the same price .
The main feature of this model is the emitter: A NICHIA high color rendering index (CRI 83) with a color temperature of 5000 Kelvin. It is usual with Nichia LEDs compared to CREE, that Nichia produce better CRI than CREE at the same color temperature, which speaks for smoothness, uniformity and quality of light of Japanese issuers. My experience with Nichia LEDs is limited to 5mm latest generation of this brand: 5000, 4200 and 2700 K have excellent color rendering and a light beam with the same light tone although the intensity varies, which not always occurs in the CREE leds, where the central focus of projected light usually has a warmer color than the rest of the light beam and also its neutral and warm colors usually turns too much to yellow.
The LED is a 219, which die is comparable and weldable in the same stars that Cree XP, unlike Nichia 119, that need dedicated stars.
According to the website of Illumination Supply, LED is the NCSW219AT. “W” indicates the neutral tone of light (5000 K) compared to the L-tone indicating to neutral-warm and pure warm light (4200-2800 K). The 219 is compatible encapsulated in solder with Cree XP; datasheet of this model provides between 100 and 120 lumens at 350 mA measured at 25 ° C (bin B11 which is featured on Nichia official website), equivalent to a bin Q4 / Q5 in the XP-G2, performance that is not the better. The bin of these Nichia reaches till the B14 (AT model) and B16 (BT models), the latter has an equivalent performance to XP-G2 S2.
Led picture:
The presentation of the flashlight is in the line of premium brands: laminated cardboard box with basic ANSI-NEMA data printed, which contains the flashlight, battery, spare o-ring and key ring, along with the instructions in English and Chinese.
The appearance of the flashlight is excellent with a soft anodized and solid appearance: the thickness of the tube does predict a good construction. Centering led, threads, spring and twisty confirm this. The rotation of the thread is soft but enough firm indicating that the O-ring is well-dimensioned; good sized spring offering little resistance but holding the battery without dance. Flashlight is held in tailstand, and the split ring fits perfectly into the recess of the tail to allow it. It has mechanical protection against reverse polarity.
The knurling is rather deep but not aggressive, very good machining:
In the hand:
Rather compact size, but not so much like the old Fenix E05:
Performance: the brand advertises 29 lumens for the model with Nichia (the sample of this review) which is 6 lumens unless the version with led Cree XP-G2 with cool white. In both cases the measures are ANSI-NEMA standards. The user UPz has had the great detail to allowing me the publication of its integrating sphere test (with a Eneloop labeled in 750 mAh) whose data offer a very flat curve of performance, which was expected since the driver does not express much the battery:
I've done a visual test with Duracell alkaline battery that comes with the flashlight torch, which has yielded worse results, not reaching the two and half hours with good performance, then a gradual decline giving a usable light till three hours approximately. Of course, the next day the battery was fully recovered and gave light to its initial level again, although I have not repeated the visual test with the same battery:
Although Rayus cautioned not be used lithium batteries 10440 because otherwise the flashlight can be damaging, in the ShiningBeam website we can read that this flashlight resists lithium-ion although the continued use with this chemical is not recommended over three minutes. I used the flashlight momentarily with LiFePO4 batteries and has worked flawlessly and with some increased light but not with much greater intensity, perhaps 60-70 lumens, far of the "wow effect". My protected Trustfire 10440 do not fit because the flat top of this battery.
Finally, what turns out to be the a very good asset (IMHO) of this model: its light tone, due to the Nichia issuer with only 5000 K, a typical neutral color temperature but still far from warm tones. Provides a 83 color rendering index, substantially higher than Cree LEDs with the same color temperature. Personally I like the tones of Nichia emitters more than Cree ones, because Nichia’s tone don’t turn to yellow, wich is common with Cree with the same Kelvin index.
A comparison with some Cree light tones, from the cool (left) to the neutral-warm (right):
The beam is not thrower, with a relatively broad central focus, and this is where I find some hits because it has a slightly darker ring around the central focus (this ring is barely noticeable, you can’t see it in the pictures) and another ring something most noticeable around the main light beam, and this one can be seen in the pictures on performance. These rings are seen projecting on smooth, flat surface, but in normal driving do not bother neither notice.
A comparison with neutral XP-G2, I admit that these XP-G2 offer very good neutral tint too:
As I said before, this keychain flashlight competes for construction quality and performance with the old Fenix E05 27 lumens, here a comparison with my E05 which is what I take as a last lashlight backup in my car keychain, relying on a good runtime.
It seems that the brand Rayus is considering the idea of offering a multilevel model 1 x AAA , like most of premium flashlights brands.
To conclude: Rayus C01 is a keychain light that offers an excellent constructive quality and good runtime, with the added advantage of being able to buy it in two tones of light, with the select tone Nichia in the case of the neutral version; high quality at a lower price than those equivalents of premium brands.
Thanks for reading
Very nice review! Thank you for doing this for us. :beer:
WOW
Really comprehensive review,
thanks much.
Keith
Thanks for the review! Looks like a nice key chain light.
Thank you for the through review.
Nice to see another manufacture offer the Nichia LED in one of their lights. For a light this small, I would think multi-mode is a great thing to have. Something like a three mode setup of <1 lumen, 10 lumens and 50-60 lumens is fine.
Thanks for the amazing review! :beer:
Yes, the news that I have are that RAYUS is thinking in release a multilevel 1 x AAA, like another brands.
Thank you all for your comments,
Thanks for sharing .
Great review, I’m getting really interested in this brand. The quality seems to be on par with the more known top brands.
nice review - thanks!
Great review and thank you.
The current regulation looks very good.
Very nice review, thanks so much, Noctiluco :slight_smile:
Good review, thanks.
Very Usable Presentation
Thanks for your review, I really love its orange peel reflector :heart_eyes:
Great review. But I lost confidence when one member here put his up for sale because of a "green tint". :Sp
Just when I thought I had found my first 219 for a decent price I have to read that sort of stuff. WTF... This defies any and all I have ever heard about the 219.
My unit has a good tint of neutral white, not greenesh nor yellow. But I guess always it is possible a sample with a "deflected" tint...
