RD tech Black friday sale Begins
RD6030 is buck mode power supply, the max output voltage=input voltage/1.1-1, so that some customer use 48V input and ask why the output voltage cannot reach 60V, the device does not support boost mode, please notice that
hello, if battery charging is auto cut off after a few seconds, please check it in this way: 1. check if setting voltage is much higher than the battery voltage, 2.check if actual current< cutoff current, 3. check if actual temperature> cutoff temperature
for RD series power supply, they are user friendly, they have keypad, big screen, battery charging terminal, for RK series power supply, it is compact design, if you just need 60V 6A output, you can check RK6006, it is suitable for small desk
for RD6030 power supply, there are some recommend accessory, first it is our 36A test cable for outoput, and if you order the assembled set, it is included, and then it is our silicone sleeve, as long as you have the case, you can use it
X36A cable is suitable for RD6024 and RD6024 but cannot be used for other RD models directly because the connector is O-type, RD6024 and RD6030 output terminals can be removed, other RD models cannot, this is the reason
last 2 days, please notice the promotion time
the last day of the black friday sale, please notice the promotion time
