RD6006/RD6006W firmware update and new functions
Hello, we have updated the firmware of RD6006 to V1.37, you can get these new functions by firmware update with PC software, but some customers still have questions about how to update the firmware and what are the differences, you can read this article to know, or watch this video:
YouTube
RD6006 link: https://www.aliexpress.com/item/4000282551930.html
RD6012P: https://www.aliexpress.com/item/1005003472332331.html
RD6024: https://www.aliexpress.com/item/1005003744641750.html
First you need to use the PC software, connect the RD6006 to PC via USB connection, and choose Firmware update–click NOW and it will download the latest firmware.
After updating the firmware, please hold the 0 button and connect the input power to restore the factory setting, then you can use the new function.(do not forget to do this step)
Here are the new functions:
·add cut off current and cut off temperature for battery charging
·add output power limit to protect the load
·custom parameter display color
·add detail mode display besides the tradition mode and curve mode, and custom font style
·you can use left and right direction button to switch the display style at main page
·add Russian display
if you have any questions when updating the firmware, you can just leave message or contact us directly
hello, we said that the new firmware of RD6006 is ready, and you can download it with PC software, after updating, you need to press the 0 button and connect the input power, so that the new firmware can be used, without the last step, there is no current, so do not forget to do it
RD6006 feedback
excellent product and excellent service
Hello, today we introduce the difference between RD6006/RD6012/RD6006P/RD6012P four devices, they are suitable for different people.
YouTube
    Before we talk about the differences between RD series power supplies, let's see how the RD series power supply comes out.<br />
At first we just have DP, DPS and DPH series power supply, they are compact design and you can change the settings just by the encoder potentiometer, they work stable but with time going, our customers has new needs, they need Bigger screen, more convenient control mode, and more useful functions…
So that we released our first RD power supply RD6006, it is 60V 6A power supply, it has 2.4 inch bigger screen, keypad control, battery charging terminal, working status indication…
People like the new design, but they need higher current version, so RD6012 60V12A version comes out, they look similar, but the structure are different, and the resolution changes from 0.001A to 0.01A because it is 4 digit display, the ripple is a bit higher from 100mV VPP to 250mV VPP.
Some customers need higher resolution, and the ripple should be reduced as low as possible. So we released RD P version power supplies, you can consider them as the update version of normal power supplies. You can see the structure of them a totally different, we add linear power supply structure so that the ripple reduce a lot, it is 20mV VPP.
You can check the comparison chart at description page to see their differences
Besides, RD6012P has 2 ranges, you can switch between 6A and 12A, when it is set to 6A range, you can treated it as a RD6006P, there is no difference.
From RD RD6006P, we use new setting page, compared with old RD power supply, they have these new functions:
you can check this video to see the actual test:
RD6006: https://www.aliexpress.com/item/4000282551930.html
RD6012: https://www.aliexpress.com/item/4001053200176.html
RD6006P: https://www.aliexpress.com/item/1005002185722889.html
if you have any needs or questions, welcome to contact us
