Recomendations wanted for a XP-E2 host
After a less than successful mod I’m left with a de-domed XP-E2 on a 16mm Noctigon.
I’m looking for suggestions for a host to put it in, 18650, 18350, 16340 or 14500 as long as the reflector will work well with the XP-E2.
If all else fails I’ll just drop it into a P60 but I’d like something a little more interesting.
Oh…drop it in a Ultrafire 602C, teeny weeny 16340 host…run it at 1400 mA (101-AK-A1 driver) just get the XP-E(E2)/XP-G(G2) to XM-L adapter ring.
Hi Infiniti,
Was that by any chance in a Jacob a60?
I am also considering just going back to the original xre in my Jacob a60, I did not really see much improvement with my xp-e2 at 2.4A vs the stock…( I did not dedome,but have no wish for a smaller hotspot…)
So I too am looking for a nice host for my xpe2….
Cheers
Anton
Oh you guys are going for throwers…ah
Like my post above…but get the Convoy C8 host, adapter, and a 2800mA 8*7135 Nanjg 105C, since you already have it on a copper noctigon…throw some light :wink:
We think alike.
WarHawk, I was considering of a UF 602C. I’ve made a few for gifts to friends and have a 3.0A 5C XM-L2 in my EDC rotation. Decent light and cheap :money_mouth_face:
I was looking at the Convoy C8 last night but would rather use a SMO reflector, anyone know of one that fits? I may just try the XinTD, if it doesn’t work well with the XR-E I can always swap in an XM-L.
Flitsmal, Yes, it was an A60. Used a single mode Nanjg @ 2.1A but couldn’t get the tight focus of the XR-E. I tried every type of centering ring/adapter I could find, I just couldn’t get the reflector low enough on the LED. I may try an XP-G2 at some point to see what that looks like.
c10 C10 group buy flashlights are in and they are turning out great. ,great thrower.with direct drive xp-g2 is a monster
someone please correct me if i’m wrong, but shouldn’t an xp emitter be seated further away from an xr-e reflector for proper focus? and if it’s dedomed then further again?
If you want a thrower, I’m really enjoying my Luxeon Rebel LEDs in a Convoy M1, even though it has an OP reflector. The pill is brass and fairly chunky, and it takes 20mm Stars that can be screwed down. Or, if the star is copper, it can be soldered for maximum heat transfer. It’s a nice product.
I think you are correct, that is what TomE was telling me to do.
I still could not get great results, so I have given up for now….
A small zoomie is nice with a xpe2.
to utilize that XP-E2 to its full potential why not go for a aspheric host? Id recommend a SK98 (smaller 18650) or an UF-T20 (slightly larger but still not big 18650)
I have a dedomed XP-E2 in an old fenix E21 with a custom single CR123 body tube. I got a very noticable hot spot increase when upgrading from the factory dome intact XP-E and the greater output of the E2 makes it so I still have a usable spill beam. Its my smallest thrower, measured 12,000lux @ 1m, 16,000 with an 16340 but no usable low mode.
To get it proper focus the emitter needs to be close to (even up in) the reflector, wether its a reflector designed for a XR/XP/XM/ whatever, you always need the emitter level with, or inside of the reflector, if its below the lip you may still get a usable beam but it will have a donut at close range. This is why I refuse to buy lights with XP sized reflectors, I’d rather use an XP in an XML reflector cause atleast it fits, try putting an XML in a small hole reflector that it doesnt fit in and its the worst beam you’ve ever seeen.
Hhmm... Did you try the other way? I did A60's with XP-E2's, but you have to get the LED out of the reflector to get it focused, than you'll hit over 100 kcd. I glued down a centering peice on top of a centering piece - kept the LED centered but below/outside the reflector - just confirmed the throw: 104 kcd. Mine is domed though - haven't tried de-domed in a A60 yet, but I know you can get 200 kcd out of them - one guy had built loads of them with that throw.
As cereal_killer said, a uf-t20 is a pretty decent host for that xp-e2. I have been modding some with xp-e2’s(reds and greens), and have been very pleased! It will give a tiny hotspot at distance, or a very nice flood. That small die is perfect for zoomies.
I started by using the centering disk that came with the A60 (unlike other centering disks in that it centers the outside of the mbpcb). I figured that would put the reflector at the same level relative to the mbpcb, the beam was terrible.
I then tried stacking the flat isolation disks from Mountain Electronics on top of the A60 disk but things were getting worse so I went the other way.
Tried XM to XP adapters from two sources, no better than the original A60 disc. Shaved one of those adapters down, still no good. Finally filed down my solder points as low as possible and went back to the A60 disk. I did not file the reflector at all which I have done on other lights.
In the end I had a very usable beam, hot spot may have been equal to the XR-E (but this with a XP-E2 at higher amperage). Problem was it had a large corona 4 or 5 timed the diameter of the hot spot. What I want is the same profile as the original light, clear defined spot with almost nothing else.
I de-domed the LED before starting, maybe I’ll try again with the dome on.
TomE, what type of centering disks did you use?
I also wonder how the metal ring around an XR-E affects beam profile.
I hadn’t thought about an aspheric, Ill look into a few.
Thanks for all the feedback.
Oh boy, think I posted all the details in a big A60 mod thread, probably over a year ago -- really can't recall, but I used a centering piece to fit the reflector hole, then used AA thermal epoxy to glue it down, manually centering the LED in the center of the oversize centering piece hole, then letting it set. Hope you can understand... Now I came to this final assembly after lots of testing/experimentation, so initially I didn't do such a permanent setup - probably used those 3M glued back isolators in layers to get the best depth. The guy illuminator .... from Eastern Europe is the real Jacob A60 mod expert, but he was a little secretive about it because he was selling a lot of them, and didn't want local competition. He did de-domed XP-E2's and consistently got over 200 kcd on many pieces. I had a few private pm's with him and trust me, he really knows what he is doing. I strongly believe the XP-E2 is the best emitter for the A60 reflector - nothing else can compare. 2.4A is probably the best. I did one at 2.8A and had no measurable improvements. I tried XP-G2's but could not get them to focus - maybe I gave up too soon because others seem to have better luck.
Tom E. built a couple of Jacobs with XP-E2’s with domes and got about 110kcd out of them. That is a worthy upgrade over the stock XR-E which does from 60 to close to 70kcd depending on samples. I have owned and tested about 8 different A60’s. It is one of my favorite lights.
Are other people getting 200k out of an A60 or just that one guy with his special methods? If so I gotta have one, 200kcd from a single 18650 light, yes please.
I hear you, but I could not replicate those results. My Jacob a60 is about 50000cd stock, I put the xpe-2 in and got about 57000cd, with an uglier looking beam…( With the ak-47c20 nanjg driven to 2.4A) I think that was with the spacer in… Then tried without spacer, not really any better… Then tried unscrewing the head, so it sat further back from the reflector,as TomE suggested, and still got around 50000cd, but could not get a real nice focused hotspot, so last night I just went back to the original xre…
Also, the reflector coating is flaking off around the led hole… Can’t complain for the price, just pointing out why I am a bit disappointed with my Jacob A60 mod…
Then stock Yezl y3 is great, although the reflector coating does seem to be flaking a bit as well… ( also around 50000cd, but much more usable spill, bigger hotspot…) All my cd measurements are taken at 3m.
Thanks
Anton
Oh boy - since I know mine are 104-112 kcd, I'd have to assume de-doming will get you in the 200 kcd - doubling kcd has worked almost every time for me in the past.
Not sure exactly where we differ. I could post detailed pics of my A60 LED setup (might have in the past). Of course there are other factors - I have an AR lens in mine, plus the reflector variations, though mine is peeling, pretty beat up around the LED, but still puts out 104 kcd - I didn't even check the battery when tested.
What are the lens and reflector dimensions?
