Recommend a new thrower
I’ve got a Thrunite TN32 that I have really liked so far. It’s pretty old, I think I got it in 2014.
Just wondering what a “modern” replacement would be? Looking for recommendations on something that throws a bit farther, has a bit more output, and maybe runs off 21700’s or built in Battery.
I do not want a handle. I very much appreciate high quality construction (think Malkoff or Surefire).; bottom of the barrel lights need not apply. Bonus for hcri, I do not like cool white tending blue. I appreciate a very simple ui, don’t want 87 modes.
Use case is lighting up the yard at a farm to see what wildlife is wandering about.
Please let me know your suggestions.
Convoy L21A or L21B maybe?
As emitter the SFT25R or something with a similarly small or smaller LES
WB, mckeand13!
If you want some usable spill (with less throw than the SFT25R), I suggest the SFT42R emitter.
Welcome back! Great request as users here can give you some advise benchmarked against the TN32; specs of current light:
LED: Cree XM-L2 U2 LED
Lumens: 1700
Max beam distance: 979 meters
Peak beam intensity: 240,000cd
Power: 3x 18650
200mm length X 80mm diameter
High end reccomendation:
I can’t see anything on Malkoff product line-up that would “beat” the TN32 in output/throw or runtime.
Surefire is silly money for bigger lights.
Premium Chinese brands: Unless I’m missing something obvious, bizarrely now I’ve browsed their “big lights” collections for the first time in ages, Nitecore, Fenix and Acebeam don’t have any “soda can” lights with deep reflector and single LED (to achieve the throw you want).
For a budget reccomendation, you could look at either the Convoy 3X21A with LHP73B, which I can’t find reviews or specs on, or, for something significantly brighter and slightly larger, the 3X21D with F150R. I failed to find some runtime graphs I’m afraid, so can’t say how hard the F150R light will step down due to temperature.
Just got a Wurkkos TD01C in the mail and it throws like crazy. Very tight spot and no spill, a good fun light.
At 936m and 1200lm, the TD01C unfortunately lags behind the TN32 in both output and throw.
For the 4x18650 or 3x21700 form factor with a similar head size, the Convoy 4x18A and 3x21A in F150R are natural candidates–either should easily do 5000+lm at 1300+m of throw. The 3x21D F150R is a much better thrower (~1800m), at the expense of larger head (approaching 90mm).
Despite the upgraded cell capacity of all above lights, the body diameter remains compact, at <52mm compared to the TN32’s 49mm.
The Convoy L21 looks like a good option. And the Astrolux FT03. I’ll check into both of those more. Soooo many LED options.
take SFT42R 5000K, or F45R for 4000 and 3000K options. they are effectively almost identical, some 3k lumens almost, and 1300m? of throw i think. i am not sure tbh lmao
Astrolux quality is very hit and miss in my experience and rarely have a good LED tint, not to mention Hi CRI. I don’t have any good thrower recommendations in soda can style lights. But I’d guess the 3x21D with a F150 R as previously recommended will be pretty good. I like the M21K with that LED.
The Map may help somewhat in rational choices and piercing through the fog of opinions - helps me:
Throw/reach between the two should be about the same and the the total outputs are only marginally different - with Wurkkos TIR probably having a little tighter spot and less light wasted on spill.
p.s. You can also find on the map some other options mentioned here and see if they are far enough from one another to make meaningful difference.
Did you get it with F150K or replaced the original LED? I have one with LHP73B, and there is nothing wrong with it, but I’m itching to make it just a tad spottier…
I got it that way from Simon, ordered it immediately when he released the F150s. It is a nice big spot. I posted lousy beamshots somewhere in the convoy thread.
This graph seems more horizontally compressed than the version I see in my browser. Reading off the graph, the TN32 has about 40% more lumens than the TD01C, and similar throw.
At comparable peak intensity, a tighter spot and less spill would mean lower total output, not a marginal difference. This is because total output is simply the integral of intensity over space, which decreases when the intensity-over-space function is truncated, i.e., tighter spot and less spill. A significantly lower total output is indeed observed.
@mckeand13 Which do you value more: reduced size/weight, or runtime on high/turbo? This should help you decide between a single-cell and multi-cell light.
A few have made references to soda can lights. Just for clarity, I’m not necessarily looking for that. I actually prefer a smaller diameter as long as it’s not too long. Preferably 1 cell.
For a non-sodacan light that has good throw and output, the highest performance you can get is the Convoy L8 with F150R, powered by a 26800 cell.
Throw is always correlated with diameter, so by going with a smaller diameter, you necessarily forgo throw. Fortunately, even the 62mm of a Convoy L21B can easily crank out 1300m of throw with the F45R or SFT42R. That’s double the intensity of the TN32. The SFT25R produces even more throw (1500m) and sustains it for much longer, though the spill won’t be brighter than the TN32.
I did a bit of research.
Those two emitters are pretty similar in throw and output. :slightly_smiling_face:
It’s 58mm
I meant the head diameter, which I believe is more relevant to OP’s “smaller diameter” preference than the reflector diameter of 58mm.
Yep! I really like the SFT42R 5000K for the excellent tint, but if OP wants a lower CCT like 4000K, the F45R has that covered.
I have the TD01C and a Nov Mu V2. Got it covered for max flood and throw :slight_smile:
