Recommend a new thrower
Lack of full clarity on my part. I prefer a smaller diameter body, vs. a soda can.
I fully understand the reflector is going to be a larger diameter to achieve the desired throw.
Understood! In that case the L8 is probably your best bet from Convoy, for absolute throw/output.
Though on a second thought, modern 21700s (6500mAh) are already approaching the capacity of 26800s (7000mAh), and is a much more ubiquitous format. For this reason, a L21B might be a better investment for the future, as the 21700 format used will continue to see upgrades in the future, while the 26800 used in the L8 risks stagnation or phase-out.
I would personally get the L21B, because it’s available with the SFT42R and F45R, which sustain much better throw than the L8 with its larger LED.
Those are both good, but for a more modern and better output experience the FT03 is ‘old’. If you want to spend a little bit, the Acebeam T29 is awesome. The C9nvoys are nice, the MK21 with the SFT90 or SFT-42R is great too.
The T29 looks like a great option, definitely interested. My concern is the 6500K which is getting much farther into the blue than I like.
The Convoy L21B is essentially identical to a T29 in size and performance, but can be had with 5000K or 4000K SFT42R or F45R.
and costs 100$ less :clown_face:
You’d be surprised that it’s not that blue. Check my 1Lumen review. The sft42R comes in lower on the cct than advertised. As much as I like Convoys, if you can spare the extra $$, the T29 is a better light in my opinion feature-wise (quality, plus onboard charging).
For a good thrower I would recommend BLF GT90, or smaller Acebeam K75 2.0.
I had GT90, K75 sill in service.
Mike
The GT90 will be too big (he wrote " prefer a smaller diameter body") and the K75 V2 is $350 - last time I checked we were on the BudgetLightForum, so I guess he doesn’t want to spend a fortune on a flashlight?
Correct. That recommendation (GT90 & K75V2) missed the mark on all accounts.
I’m not up on the cd numbers. Would the T29 be noticeably brighter than the TN32?
Like, meh, it’s a little better. Or blow the doors off better?
The T29/L21B have 2x the intensity, or equivalently reach 1.4x farther, than the TN32. The qualitative significance of this increase is up to you!
Well, the eyeball luxmeter will tell you that yes, the T29 will be much brighter and throw much farther-farther than your naked eye can see in a dark night.
Man, what’s not to like with the T29? Single 21700, a smaller (than TN32) head diameter, and higher performing.
Decision made.
Personally would go for L21B (which has equal performance) given your preference for lower CCT, but if you’re ok with cold white and find the T29’s features worth the price tag, then go for it!
Acebeam T29 en route. I’ll post some feedback here once I get my hands on it.
