Recommend a P60 Drop in for me
Wanting to update a WF-502b, I like the form factor (and low cost) of the 502b as an EDC. Would prefer to have something with 5 brightness levels, No strobe or SOS modes. I kinda like my EDCs somewhat floody…and mine currently is, even with a smooth reflector. I’m a bit skeptical of loss from an orange peel reflector, but let’s not get hung up on that detail. I also value good low modes.
I saw older threads (2011) where somebody was offering “build to order” P60 drop ins, where you could specify drive current, emitter type, mode # configuration, and custom programmed output levels. Don’t know if that level of customization is still possible.
Because Emitters and vendors change so rapidly, I figured a new thread is justified. I suppose the XM-L2 emitter is the best current choice for a P60.
All advices and opinions on a P60 upgrade is appreciated.
A lot would depend on desired runtime, presuming an 18650, not cheapest but this from International Outdoor Store lets you choose modes.
I have several Solarforce drop-ins that I like but they come in 1,3 or 5 modes and the 5 contain strobe and sos.
Try Kaidomain and FastTech but you’ll probably end up getting what you want built for you which I know little about.
Happy hunting!
The first link is pretty good Steve. 4 brightness modes is okay, and runtime isn’t the primary issue. I need the ability to stun panhandlers at night when I’m downtown, so I was looking for something with at least 2.5 amps of drive current.
Other leads on P60 drop-ins are still welcome.
Doesn’t sound like a good idea. Someone living on the street does not have much to lose.
“If your opponent can’t see, he can’t fight, if he can’t breathe, he can’t fight.” Bruce Lee
The whole point is a first level of defense, a more passive level. Its a very reasonable approach. However, if I’m required to turn up the volume, I can certainly do that too.
Let us turn our focus back to replacement P60 Drop-ins.
deree light has a few options.
I’ve used this combination a few times:
1: Empty drop in
2: Driver
3: Emitter
If you want “blinding” bright then an XM-L2 driven hard [3A+] is what you’re looking for. BLF member E1320 makes outstanding drop-ins but I believe he’s not building any at the moment. There are other custom builders that will create whatever you want, all it takes is $$.
I will suggest you consider buying a SolarForce L2 host, it’s much more rugged & reliable than the UF502, has better heat sinking ability and comes in several variations; L2, L2M, L2N, L2P. Check out Solarforcesales.com.
As TSellers suggests you can build your own P60 drop-in if you have some soldering skills. I’ve built many, it’s not difficult just a bit fussy since you’re working w/ small connections and thin wires.
