recommend C8 parts
a few months ago I put together this:
Convoy S2 Flashlight host
QLITE REV.A 7135*8 3.04A LED DRIVER
CREE XM-L2 T6 3C LED on Noctigon 16mm MCPCB
I really like it and it replaced my pd30 q5 as my edc. I am running it stock in the 3 default modes. now I am looking to put together a C8 that is not as floody, and maybe a tiny bit higher color temp/ tint. like the qlite driver but should I get it modded for
more output? and which led would throw/be tighter? any info would be appreciated
XP-e2 will always throw the best but have the lowest total output, XM-L2 will flood the most and have the most total output (but it’ll still throw well in a C8), XP-G2 will be a middle ground for both and seems to (from what I’ve seen) have a slight lead in popularity for what people prefer in their C8. Since your specifically looking for more throw I’d say go for an XP-G2 @ 3A but even if you decide to go for max lumen with an XM-L2 it’s still going to throw way more than your S2.
"higher color temp/ tint" as in higher numerically (cooler)?
BLF-17DD* off-time driver, smooth XR-E reflector, dedomed XML2 U2 1A (or XPG2 S2 2B if you don't want to mess with dedoming).
*Despite the price, this is a not-too-bad starting point: http://www.fasttech.com/products/1562700 The aluminum pill it comes with takes a 20mm star & 20mm driver (so substitute a BLF-20DD instead of the 17), and the pill threads are the same as other standard C8s (i.e., most everything except the Convoy C8). The reflector is plastic but that really matters very little - aluminum & plastic reflectors both get the same coatings. And the reflector is dimensionally the same as the good-throwing XRE parts (wide flat base around the LED).
yes— a slightly cooler/whiter color. thank you, I will look into those
parts. anyone else?
