I was looking for a folding table for laptop. Found this one on BangGood website. Is it a good one?
Has anybody used a similar product and can recommend it or recommend something better.
Many thanks for any help you can offer.
I had considered one but decided to get the simpler Ikea Brada, the kind made of laminated plywood. It folds up quickly and I like the design.
It doesn’t have a fan but I found I get more efficient cooling running a single 80mm fan to blow air horizontally across the laptop (difference of some 4-5°C idle, which is a lot considering its 27.2°C here indoors) than forcing air upwards from underneath (I was using an aluminum Akasa cooler prior, which has a pair of 70mm fans).
Be careful when ordering from online stores, you get no idea of how strong the tables are. That Ikea one looks good.
I fitted a double capacity batter that sticks out of the base of my laptop by about 35mm that helps with the cooling. I rest the laptop on a chopping board, I’ve got 2 a bamboo one for home and a resin one for travel, it has the added benefit of giving protection while in the laptop bag, fix a cushion of the right size to the base of the home one and it’s a good sitting or sitting in bed table for your laptop.
If you want to spend a lot of money then one of the hospital tables on one pole where the legs fit beneath the bed are perfect.
