Recommend K1 replacement.
Hi.
I love the K1 but it keeps having issues. The switch is terrible in that light it has been replaced twice already and tonight I want to use it , it was hard as a rock won’t work.
Must have.
1.Must be SBT 90.2 or something comparable.
  1. Must have Anduril / Anduril 2 or driver where you could disable the step down.
  2. Narsil?? Not sure if that is used anymore lights. My fto3 had that in there you could disable the step down.
  3. Similar sizes K1
  4. At least 4800 lumens and 500 kcd.
    Mine was measured at 5100 lumens and 550 kcd.
$150 or less.
Thx
Edit:
Yes..4800 Lumens Not 48000,NOCTIGON K1.
Must be 21700 battery.
Thx
48000 lumens, 500k lux and same size as Noctigon K1 for less than $150?
I don’t think such a light exists. To get over 48000 lumens you’re probably looking at huge multi-emitter lights like those made by imalent, they would probably cost several hundred dollars. And nothing with the specs you want in a relatively small light is available at any price. The tech doesn’t exist I think.
The only K1 I know of is the Noctigon K1. Maybe you’re thinking of a different light. What brand is your “K1”?
I think the 48000 was a typo and 4800 was the real number based on the similar candela for the two flashlight comparisons.
He probably misspelled 4800 lumens
What do you mean disable the stepdown?
Cheaper k1 would be Convoy 3x21d Sbt90.2
Convoy L21B sbt 90.2 or sft40 6500k, sft42r
Fireflylite E90 sbt90.2 it has Anduril
You are right..mispelled 4800..SEE edit.
. I have Convoy L21B with some other LED, not SBT 90.2. That is measured at 5800 lumens, 420 kcd. Thanks
My FT03.Narsil has a Disable step down..
I Found someone to fix it. HL Hawaii. Jackson Lee…recommended by Hank.Int. outdoors.
Including original cost of light…repairs since 2019..just over $400​:astonished_face: not including this repair!:flashlight::nerd_face:
