Recommend small zoom flashlight host for Osram CSLNM1.TG/ CSLPM1.TG
hello friends at blf!
I recently make a 'floody' light with convoy S2+ host, and I plan to try something new, to make a 'throwy' flashlight. I hope to use new osram led which is good for throwy beam. But I still want flashlight to be compact.
Original I think of using Sk98, but I hear it is bad flashlight as host. Then I found that convoy c8 and emisar d1 are recommended, but they use reflector not zoom lens.
May anyone here have suggestion on which single cell (18650 or similar) host I can use?
Thank you!
Brinyte B158 / B158B, for sure. I have a B158B with a flat white and LED4Power Driver that does about 400kcd.
On The Road i3
Is a 16340 flashlight and uses 15mm de driver! (I would advise to change it if you go for one)
I love mine :wink:
Mountain Electronics sells the Ultrafire Uf-T20. It is a reasonably small Aspheric zoomie and it gets decent reviews. It is just about as large as a pocket able light can be.
Thanks everybody for suggestion. I will continue to search!
