Recommendations for high-power LEDs with a beautiful beam profile to buy from Convoy.
I considered the LHP73B, but it requires high-discharge batteries, and I wanted to be able to use higher-capacity ones, like the Vapcell 6600mAh and 6800mAh models. Another question I have is whether these high-discharge batteries can be used with LEDs that have lower requirements, such as the XHP70.3 HI.
The site says 3V 20A
but these batteries can give 12.5A… !?
Probably you need other batteries with higher discharge amps… !?
The battery discharge Amps should be higher than the Amps that the emitter needs, so both can work perfectly together !
At least in my opinion !
You can still use LHP73B or any other high power LED, but with 3V 10A/8A driver, in that case they will be more efficient.
These new batteries can’t be used to their full potential because Convoy drivers discharge Li-ion to 2.8-3V, the advertised discharge capacity is measured at 2.5V or so.
You can use any drivers and LEDs with any batteries as long as battery CDR is higher or equals driver maximum current.
You can even use 20A buck with ~10A CDR batteries if you choose mode group with 50% maximum.
