I got HD12 and I like the light but I find the tint and CRI rather muddy. I’ve never done any swapping and have no tools for it, but I found a person here in Thailand that will do it for me.
I’ll buy the LEDs from Convoy. But I wonder if someone could comment on what to buy.
The lights I have with the tint I like are HS21 Flood and FC11C 5000K, with the latter’s Nichia 519a being a little less pinkish than the HS21. I like them both.
I was thinking of buying 2 Nichias 519a in 5000K, but are there other choices that would work well with HD12? Should I expect the 519a from Simon to be similar in tint to FC11C? The 4500K are out of stock - is that permanent? Does it make any sense to mix CCT - one in 5000K the other in 4000K?
Also, would 519a have similar forward voltage to the original LEDs , and if not, how differently it will be driven by the driver?
If less pinkish is a good thing for you then tint mixing might not be ideal, the resulting tint will be more pinkish than both primary sources. I like my tints as neutral as possible, so i would choose a LED in the intended CCT and use it in both pads.
Now I have two Nichias 519a 5000 K from Convoy in HD12. I like it much better than the OEM, but for a romantic but still accurate headlamp I was thinking that something a bit warmer might be better.
What to expect if I dedome one or both of those LEDs before trying 4000 K variety?
