Reinstalling Windows 8 on SSD, how can i make a backup onto another drive so i can go back to fresh windows in future quickly?
Back in the old day (WIndows 95-XP) i could just copy the Windows and program files folders and zip them up so the next time i wanted windows reinstalled i would just rename the old folders ones, copy the backed up ones, make sure it worked then delete the old windows.
Can i do this with windows 8, or is there another way, i’ve noticed some files won’t copy so i don’t think i will get a working version if i do this.
Imaging software. I use Acronis True Image
it looks good, but it has to be a free software
Macrium Reflect Free edition?
Makes a carbon copy of the drive.
Some hard drive manufacturers have free drive tools with cloning utility. Seagate DiskWizard for example, works with Seagate and Maxtor drives.
Its a samsung 128GB SSD
Okay, it looks like this has custom cloning utility:
It might be a little more complex to use but Clonezilla works great. It allows you to make an exact copy of a drive and either save it to a usb or network storage location to restore at another time or you can copy it from the SSD to another hard drive to have an exact duplicate ready to plug in at any time.
http://clonezilla.org
+1 This!
+1
Have a boot USB drive or DVD (has to be a live OS, can’t run Windows for a disk image as a running windows locks files in use), hook up an external drive, use the above to create an image of the entire drive…done
Wipe old drive, install…if you want to go back to the EXACT the way it was before, pop back in that USB boot media, restore that image you made previously
done and done
Ultimate Boot CD is linux based…but has TONS of useful apps for diagnostics/repair/imaging
http://www.ultimatebootcd.com/
There is a UBCD4Win (windows based live cd) but you have to build it yourself due to copyright stuff
I found a western digital Acronis software so i am testing it now
[quote=WarHawk-AVG]
+1
done and done
this is a problem, how do i restore the windows with only one boot drive, in the old days i would unzip the fresh install, boot to DOS and rename the old windows folders to something and rename the unzipped folders to windows and other folders.
i installed the acronis and backed up my current windows, lets say this was the fresh one, how would i restore it to the SSD?
In addition to the already mentioned Clonezilla, here are a few more options:
http://www.fsarchiver.org/Main_Page
I am liking this Macrium software, i can mount and explore the saved image
My plan is to reinstall windows, install a few base applications then install macrium and make an image for future use. I will assume there is a way in future to restore that backup to the SSD when that windows installation rots?
Use a partition clone/backup software that you can run without a working operating system on your SSD. For instance by booting up from a USB thumbdrive or CD. Or another harddrive. I don't know if this is true for the software you mentioned. It may be. I would use a Linux tool, as was mentioned earlier.
And test! Don't assume that you can restore the backup image. Actually do it! Perhaps several times.
I run Windows only in a virtual machine using Virtual Box. My main operating system is Ubuntu Linux. This means that I can make a fresh copy of my Windows install every time I need to use Windows, and when I am done I can delete the copy. Important data and files I save on a NAS, also backups of the virtual machine images. I can have several different "computers" for different purposes. For example I have one virtual machine for programming, one as a Web server, another for book keeping and taxes and yet another for running a few old Windows programs now and then. And I can run several of these virtual machines at the same time.
I would like to test it, but i don’t have that kind of time
I got windows reinstalled but i am convinced its a highly defective piece of software, every time i reinstall Windows 8 it tries to install updates. The internet always loses connection while the updates are downloading, and they never get installed. New updates install but those original ones don’t and there is no way i can convince it to redo those that failed. In old versions of windows i could but not on 8. I can leave the internet running for days or weeks and it won’t lose a connection but reinstall windows and after 15 mins it does without fail. So either i am unbelievably unlucky or there is a defect somewhere in it.
Then you have the wrong solution to backup your windows install. Hire someone to do it for you.
I do this all the time (even had to today as a matter of fact). I am well over reloading software! What you need are the following:
1. USB Flash drive (used to make a boot drive with Linux Unbuntu which is Free)
2. Spare hard drive or enough space to store a copy of your hard drive BUT NOT the same drive (sometimes drives fail and there goes everything)
3. Boot into Linux and then copy and paste your complete hard drive wherever you want.
FYI - most of these companies including Acronis are doing the exact same thing except they develop different UI's that everybody sees.
Should you end up with file corruption or a bad drive just boot in Linux and copy and paste to where you want it.
I wish i had the money, my data files backup is automated, i use bvckup, once a day it syncs my data drive with the backup drive. I had it on instant backup but it was spinning up the removable drive all the time and once i wanted to revert something because i didn’t like the rewrite i did on a document so i went to once a day backup.
This windows restore is just gravy (well future time saving i hope) so if it doesn’t wok i’m not losing any data, i’m just not saving time.
If your backup drive is constantly connected and powered up then it isn't a backup.
I really don't understand why people cannnot understand the concept that a backup drive running full-time and always connected is subject to the same risks from power spikes, viruses, wear and tear, etc as your regular internal hard drive. Yet that is often what I see when some nuff-nuff has setup a so-called backup system for my clients.
It may be OK to have a fully automated service running on a network and backup up to a network share (if that network share is also properly backed up) but what you describe is not acceptable for a secure home backup.
I advise my clients to learn to run the backup manually and disconnect / power down their backup drive at other times.
For instant full-time backup of critical files, you can consider cloud services such as DropBox.
