My wife rides an electric bike to work now. But the bike is an oddball; it wasn’t home built, and it’s not one of the major brand builds like Bosch. Its a diamondback, and they went with Currie Electric drive components. So without hacking at it, I don’t have access to the 48v mains.
But it did come pre-wired for a headlight and tail light! Very conveniently, it has a headlight switch, and it will even automatically turn on the lights with a light sensor. The problem is, it’s a full 6v and recommended 5 watts! :person_facepalming:
I’d like to retain the original functionality of the auto-on feature.
So should I use the 6v to power a relay to turn on an entirely separate system? I’m not averse to hanging a separate bag battery.
Should I just deal with meager power output I’m given?
Anyone have any experience creating a remote-on function?
My rough idea was:
An SRK head filled with copper and 3k lumens’ worth of LEDs and no driver; just direct drive off the batteries, but configure the leds, the battery pack and wiring so that the LEDs run at 90% or off. And a relay switch that turns the SRK head on/off using the low power the bike provides.
So, does the system send exactly 6V to the headlight, or could it be a bit more? If it’s like a 1S lead acid cell, it would have a max charge of 7.2V, and could power a CREE XHP series emitter directly. Even at exactly 6V, you could get over 2300 lumens (at the emitter) from a XHP-50.2 K4 bin (highest bin) while only drawing ~2.5A of current (voltage limited).
you could power with the 6V a FET that acts as a forward tailswitch for a momentary switch light like SRK
advantage to a relais it takes almost no power to switch
Narsil can be configured to power on at turbo, moon, 2 Blinks and no output
I got 5.97v from the leads. And it gave .11a with no load just direct short thru the meter. i thought about just DD’ing right off the given 6v leads but with that flimsy .11a i got, i figured it wouldn’t do much. the bike has a computer, and it gives the 6v, so it might limit power too idk… they don’t really have a wiring diagram.
hmm i’d love to put a remote eswitch on the handlebars that she can just ramp up and down like the D4. but it can’t run off the 6v power supply… what do you think about this?
[/quote]
Maybe I’m reading too much into the specific word choice, but the manufacturer material says, “We recommend that the headlamp and taillamp draw no more than 5w power.”
I’m thinking that they put that “limitation” on their marketing material in the interest of overall range/battery life for the bike, instead of an actual restriction on headlight power. How long and what gauge are the wires for the headlamp? That may be a good indicator of how much power they intended the headlamp to use - if the headlamp wires are 6ft of 28awg then yeah they won’t support 20W of headlamp power.
You said you tested and got 0.11A draw at 6V, that is way below 5W - something is not quite right.
I agree with DavidEF that a 6V XHP 50.2 would be an easy way to get around 2000 lumens, which is pretty good for bicyle use. (Of course I’d supplement the bar-mounted headlamp with a helmet mounted light as well).
I’m not sure i understand the end goal But i like where this idea was going; the tail switch is activated by a relay, ignited by the 6v bike power, and the eswitch on the handlebars, and the driver running narsil.
What do you think?
I’m afraid it’s exactly that; i’ll take a photo when i get home and we can judge, but it appeared to be some 5 watt wiring going on.
so either it has very wimpy output, or it will limit itself to very low output as a protection… seems like either way, i’m not going to get much out of it.
I’m an electrician, but not an automotive electrician. So I could be wrong, but I think the “no load” current draw has little-or-nothing to do with the amount of power the headlight supply chain can handle. The wire size is definitely a better indicator. The system should be able to support an incan bulb. If so, a 6V 5A incan is quite small (output) already, so I doubt they’d make it even less capable than that by using too small wire. I hope it isn’t really 28 gauge wire!
There are some nice ~3V LEDs you could put together in a 2S2P quad and still get a lot of light, even at less than 6V. You could do it with 4x XM-L2 U3 and get ~1700lm using ~1.7A of current. Or, use a buck as has already been mentioned. Then, you could use up that available current on a single emitter and get better throw, which is probably going to help you more on a bike than a flood of lumens would. A good “single cell” boost driver for XHP35 would possibly give you everything you can get from your source, beating all other choices if done “right”.
ok, well i’ll try the load amp challenge when i get home.
reason i’m trying to get an L6 head on is because i’m in apartment now, with no tools and no working space, so coming up with a custom solution will be tough.
but a relay, some wiring, crimping on a few connectors, a readily available battery bag and somehow affixing an L6 head to the handlebars might be doable.
How long does your wife need to ride between light recharges? That might be a key piece of info that we don’t have yet.
If you are not able to use the existing motor battery and its already available wiring as-is, I think you are going to expend a fair amount of effort and cost with the idea you proposed above. You will need to source a new battery and mount for it, a weather proof switch, make a custom mount for the L6 head (and waterproof it somehow), and weatherproof the wiring to hook it all together. And IMO all of that effort will result in a less effective final product anyways. The main thing I don’t like about the L6 head suggestion is that there is no control of the beam pattern with regards to glare – it’s all well and good if your XHP 50.2 is pumping out 2000Lm, but many of them are escaping upwards from that large beam.
I see some distinct advantages to using two Convoy S2 triples attached to the handlebar:
easier to install with cheap, and easily available mounts
wide availability of choice of 20mm optics – one light can run an elliptical optic, and the other can run a narrow spot optic, and the combined beam pattern is better than an XHP50.2 in an L6 head.
redundancy against failure won’t leave her in the dark if one light fails.
waterproof right out the box
Two S2 triples could provide a similar 2000Lm to the L6 XHP50.2 with the advantages listed above, the main downside would be that they would be limited to about an hour runtime at that output level before a battery swap is necessary, the L6 with external battery pack would provide longer runtimes. Of course, there is another option with external battery pack which I use that kind of combines the two – a bike light head like this modified with driver and 20mm optics of your choice (one elliptical, one narrow spot is my recommendation as above) and an external battery pack. Then I use a helmet mounted light as well, for redundancy, but mainly for a light that I can “aim” easily at whatever.
yes you are right: it’s unlikely i would land getting an L6 head mounted to the bike, successfully waterproofed, etc.
What is this image you have here? There’s a bike light that looks similar that @garrybunk is currently tinkering with, and i think old4570 also has one of, but it’s unknown at this time.
But you have a working piece there?
I actually already have the S2 mounted on the handlebars, but i’m hoping for a bit more runtime, and a more seamless piece - something that just comes on and turns off automatically (as the bike already offers this functionality)
but even if i lose the bike’s functionality, i could be very interested in your option.
i had strongly considered this @ $205, with quality battery, three different optics for flood throw and floor, thermal management, LVP… this is a pretty nice piece with good reviews over at mtbr.com
but then i discovered the bike is prewired and was hoping to do something with that; it would be great to utilize the light sensor for auto on/off.
I had my eyes open for a cheap light in this style that would take 20mm Carclo optics, and I got this one for $5 on one of those “Amazon Deals” sites because for $5 why not? But even for the asking price of $20 it’s not too bad. In stock form it was not great - angry blue counterfit LEDs making 400lm, the battery pack was garbage, etc. But as a hostit was OK:
heatsink / heat transfer improvements
driver bump
weather sealing improvements
LED emitter swap
20mm optics swap
replace the mount
(and it would have required a battery pack if I didn’t already have several that I’ve used for Magicshines and other lights over the years)
… but after a couple hours work and a few bucks in parts I’m fairly pleased with it.
For a bike light I would go with an asymetric reflector or TIR that provides high and low beam profile like on a car
just a flood and throw optic would not be good in normal traffic situation as you are blinding other vehicles
The battery pack with a relais is OK, but you better get a reverse diode parallel to it to filter the off spikes
Anyway I would do this with a FET and resistor
Meh, i think in real life a downward pointed beam is usually the best on a bicycle.
That way a slow cyclist can see the spot coming before you overtake him.
But when you’re cycling in the dark without street lighting a ‘high beam’ is preferable.
With a headlight on your handlebar it would suffice to be able to point it up or down a little.
You can use the switch on the light itself, no need for a wire and a button.
Don’t forget to point it down in traffic though (so you don’t blind your fellow cyclists from the opposite direction, choose a neutral white LED too for the same reason)
By the way, 5 Watts from a good LED headlight is pretty bright.
