I’m new to this whole modding thing.
So, I wanted to try something. I found in my shelf totally useless UltraFire S6 just because I hate that strobe.
I decided to play with my cheap light.
It’s from here .
I remember that some time ago I read about it here on different flashlight but now I can’t find that topic.
So, I don’t care if I kill driver of my light.
I opened it and then brilliant idea came to my mind. To write here. lol
Do you guys have any idea what should I connect / remove to get rid of strobe?
I’ll play around anyway, I just tought maybe you guys could help.
Numbers on driver “cx-3117-03c”.
I don’t know why but for some reason I want to remove that brown thing. What do you guys think?
Thank you for your reply.
I just removed it, and yeah, now I have single mode light. Actually that’s great for this light. Now I get something like 900mA, way better that direct drive because of heat.
If someone have any other idea how I could keep two modes I would love to hear that.
I have three of those from the same store. I didn’t really try them. I put an XPG2 in one to see how it was. I was happy it only had one mode.
After reading your post, I tried a different one… Five modes. I took apart the first one, looked at the driver, and reinstalled it. Now it has five modes.
My driver is a little different than yours. Unless I’m mistaken, yours seems to have second LED Pos. Pad.
Anyway, even with an XPG2 it’s pretty unimpressive. The beam is ringy.
I don’t really want to up the current because of the silly pill. I tried an optic, but didn’t like it. What do you want from a $6 light?
I just wanted to mess around with it since this is my first time trying to mod a driver itself. I thought maybe it’s possible to make it as two mode flashlight without changing driver. Well, this flashlight was more like $4 when I bought it lol. Actually I got more than I expected for money.
I have many other lights with strobe that I hate. I thought this is good place to start to try to get rid of it. :]
If it's a 17mm driver, then this 2.8A driver can be used (over powers that emitter though), or if it's too much power for what you want or if double-sided won't work out, than this 1.4A driver can be used. They are configurable, but both have options to have a simple 3 modes, no strobe. This is pretty much the most common way we get rid of flashy modes, and also gives you control of amps you would like. This size EDC would be better with 1.4A because 2.8A will get very hot in a couple or just a few minutes. Along with the driver, I'd swap the emitter out to something better, like an XML or XM-L2.
The reason why you can't just eliminate modes is because there is a micro-processor on these drivers that is programmed to implement the modes, so usually the only way to eliminate the modes is to re-program the driver, but that's very difficult on most of these drivers (difficult for CS's or EE's even). The Nanjg drivers that use the Atmel Tiny13A micro is usually re-programmable with the right software and hardware: software for development/compiling/linking, hardware for plugging in to the driver to access the processor to download software/firmware to (a USB dongle along with a ribbon cable with a clip). Great ref info here: http://flashlightwiki.com/Driver.
The pill is just a little barrel of thin aluminum that just drops into the head. It is isn’t even threaded, just drops in loose. 1A is about all that’s healthy for this baby. They generally cost $3 to $6. I was surprised that the lens is glass.
If you keep the capacitor and trace some pencil line on it, you can get it to reset back to High in 1s or so. Then you can have High-Low and never see strobe.
This pill will screw in if the threads are the same, just unsolder the emitter leads, pop out the driver, then throw away that useless pill, don't drive the LED over 1A otherwise it will get WAY to hot too fast because there just ain't hardly ANY metal to soak up the emitter heat (or transfer it to the body), my convoy gets about as warm as this cheapy running at 2100mA, it has more meat and the better pill.
I ordered the same light, was told it was junk...it's a $4-8 flashlight for a reason (now I know why!), the Convoy S5 at 2100mA is a MUCH MUCH better light!
