I have a 9x Beast driver, is there any way to remove the low voltage protection?
Maybe just lower it so I can run on two batteries at 7.4volts?
I never had one last long enough to actually hit the low voltage protection...
If there is a voltage divider circuit like what is used on the 105C/attiny13a drivers, then it would be pretty simple to disable it; if there is no voltage divider circuit and the voltage is all referenced internally, then there would be no way to disable it besides reflashing that MCU.
Aw that’s sad to hear, I’m running my 9x on 7 xml’s which may be contributing to its longevity…well until one burned out, and I haven’t had the time to replace it.
BTW thank you for the quick shipping of the order I made last night ![]()
Is a voltage divider circuit complex? It’s a difficult driver to look at because of the two stacked pcb’s.
No, it is just two resistors and is pretty simple. It "divides' the voltage so it's low enough to be compared to the oftentimes lower internal voltage reference (1.1v in the case of the attiny13a).
These are the little guys on the 105C
Basically, look for a set of two resistors, one that feeds from ground and one that feeds from the voltage source to be read then into the MCU. If it's not there, then there is no voltage divider. You may have a hard time getting the beast driver apart.
Should I expect to see similar resistor values? (Probably not since it’s for triple the voltage…)
No...and I have no idea what the internal reference voltage would be if there is one to. A lot of the MCUs used on these drivers don't use a divider, so don't expect to see one, but you might get lucky.
http://i1.minus.com/iXdk3HQsG1HNF.jpg
This is an image stolen from u/MomentumExchange
I can’t make too much out of it, maybe you can?
I’m hoping to avoid my already fragile driver being pulled apart…
What batteries are u using?
Well I like to vary between 2x26650’s and 3x26650’s. The flexibility is nice, and when running the 2 it flashes and makes the flashlight basically useless (The price I have to pay for using the 9x driver in a 7 led flashlight)
Running it on only 2 cells makes things very very hard for the already failure-prone driver. Don't do it.
I did not know that, what about it makes it difficult? It draws a lower amperage.
Does it have to boost the voltage too much?
The closer Vin is to Vout, the less work the already stressed driver has to do. They are not reliable even when run at what should be well within specs.
