I need to find a replacement of my old ITP A3 EOS Upgrade and I’m looking at Fenix E05 85 lumen 3-mode edition which seems to be a nice alternative. I like the E05’s slightly higher Medium level (25 lumen) compared to Olight i3s medium @ 20 lumen.
But the 3 min timer constraint on the E05 is what keeps me from buying it. I won’t want to use a light that dims in 3 mins while I’m walking in the woods at night and I need clear vision to see far away. Is there a way to workaround this (mod)?
If not I wonder if there’s any other comparable 3-mode key chain 1AAA w/ High around 80 lumens and Med around 25 –35 lumens?
and they mentioned when they ran the ANSI test in the lab they disabled the E05 3 min timer (on high) to produce the 45min/1h runtime result for high mode.
So it looks like they were able to run the E05 on high continuously (in order to get the ANSI test result) w/o any problem. And their response tells me there’s a way to disable the 3 min timer.
Don’t know how accurate this info is from Fenix customer support, but some folks might be interested to look into the E05 and confirm this… .
I think it’s fair to assume that you can only disable the timer by removing all the modes. That would be a perfectly normal thing to do during testing…
Wish I’d found this thread before buying mine. Haven’t needed more than lo or medium, just been using hi to impress the troops. I use mine mostly for ‘handy and quick’ light at work. If it needs more light I grab a bigger one so I never ran into this or I would have bought something else If it didn’t smoke at ANSI, why can’t they sell it to us that way?
