Hi guys,
my mother is sad, cuz the battery pack on this device died http://www.robotsamba.com/en/
So now i’m in the project of replacing that batteries. First i measured them, it says 22mm in diameter and 42mm in length.
Secondly i found this data sheet http://www.robotsamba.com/manual.en.pdf where it says that rated voltage is 14.4V, rated power < 24W, input voltage/current 24V—–1A, battery capacity is 2200mah.
So now, what are the best nimh’s i could fit in here? They don’t have to be the exact same type/size of batteries, just so that they fit in the space for them. Could i put in a few eneloops, or what would you do?
Actually all those linked ebay cells are total garbage.
The ni-mh are useless and ni-cd have like 400 mAh capacity if any.
If you wanted to be serious, your best replacement would be 5 Lifepo 26650, but the question is if you want to be serious with a device that is nonsense itself in the first place.
I see a theory speaking. IF Sanyo made them it could be possible but even than they would be crap as all those hi-cap rapid self-discharge ni-mh.
Please get some cheap chinese ebay cells and than speak.
did the measurements and 5x18650 lifepo should fit unlike 26650. Smaller capacity, but longer life. The charging circuit is unknown. Should be checked and observed first.
Sticking with Sub-C cells is possible of course, but you have to source the cells from some reputable place. Soldering those 16 little things is something I’d myself want to avoid.
Maybe not being lazy and vacuum clean with something serious that won’t just make all the dust airborne is the best solution.
I was at Frys Electronics today looking thru their battery section and they sell some cells that literally say exactly “Robotic Auto Vacuum ” as well as RC Car and Electric Drill with pictures of all three……They looked to be about C sized- I thought that’s what this post was about!
Soldering should not be a problem if you buy them with tabs already soldered,then you have to solder directly tab to tab, and you won’t have to solder directly to the battery. I think your best bet is to buy some sub c with tabs, and you won’t have problems with charging, size, modifications, etc
