I have read this before as well, but not sure if that’s how it actually works. Maybe it measures voltage/capacity/internal resistance.
Lots of people have taken laptop packs apart for its batteries, but this is the first time I see someone trying to put in new cells into one. I would just simply purchase a replacement pack from ebay, it will costs less than the batteries itself if you’re going for the decent ones.
https://www.ebay.com/sch/i.html?\_from=R40&\_trksid=m570.l1313&\_nkw=j1knd&\_sacat=0
If you want to use your existing cells, this pack has 3S2P setup. Without a li-ion spot welder you can use a dremel or sandpaper to scrape off the superficial layer off the contact ends (otherwise solder won’t stick), then solder nickel tabs. Try to make it as flush as possible. Can’t help you with the cell calibration or resetting the PCB, but try to use cells that have the same internal resistance and capacity.
