Hi, i got the ultrafire M5 R5 the other day and I like it. It has been on the market for two years now but I did not find a review on it, so this is my small one. I got it from dx for $1.30, like quite a few others
It is quite small, but not as small as the ITP A3, or the Thrunite Ti. It seems very sturdy and I find it good looking. The clip is too stiff but it can be reversed. Anodising is good, and the clip seems to have some low quality PVD-coating, fairly nice. Threads were lubed and go very smooth. One-handed operation is the easiest I have experienced with AAA-twisties.
It has a nice deep OP-reflector. The led was off-center, but loosening the front end of the head, shifting the led board a bit (=not glued, has white heatsink paste), and tightening it again solved that nicely.
The head opens up in two parts, the middle section actually being the pill, the driver and the led board seem directly mounted on this body part, nice for heatsinking, on an IMR battery the body got hot really fast. The reflector screws into the front end of the head, I tried to tighten it a bit more but this caused the front o-ring to pop out. For me it is not a big deal that the reflector can not be screwed very tight, but the o-ring groove should have been a bit better. Between the two head parts is a thick rubber o-ring that presses the led board down when the two parts are screwed together. In an earlier version of the M5 it appears to have been a hard plastic ring (that ruined the focus), this rubber one would also have not been my solution, but it seems to work alright.
A white wall shot against the Thrunite Ti. Ultrafire on the left with a NiMh, Thrunite on alkaline on the right (the output of the Ti is not much different on NiMh). The Ultrafire has a nice beam with a few faint rings in the spill, with a bigger hotspot and higher overall brightness compared to the Thrunite.
Numbers:
On fresh Duracell alkaline: battery draw 2.15 A, fast declining to 1.9 A then slowly going down. Output 94 lumen, fast declining to 84 lumen, then slowly going down.
On NiMh (Duracell 'stay charged'): battery draw 2.43 A, fast declining to 2.00 A, then very slowly going down from there. Output 136 lumen, fast declining to 125 lumen, then very slowly going down.
On Efest 10440 IMR: battery draw 1.8 A, fast declining to 1.7 A, then slowly going down from there. Output 360 lumen, fast declining to 335 lumen, then slowly going down.
I did not measure runtimes, but you can roughly estimate it from an average current draw and capacity of the cell (my runtime guess for NiMh is about 25 minutes).
Conclusion:
This flashlight looks well build and I can not yet think of a reason why it would not survive some long and rough use. The output on NiMh batteries is excellent. For the big wow you can have a quite insane output on IMR 10440's (for <10 minutes that is), the light heats up quickly then, I think the heat dissipation is not bad at all. It is on my shortlist for emitter upgrade and copper board
Thanks for reading.
