The light puts out too much heat for turbo to be usable for more than a few seconds
I have the Nichia version. Ran it on turbo for over 5 minutes. By the 5th minute, it was starting to get a bit hot… still OK to handle, but if I squeezed hard on the head it was uncomfortable from the heat. Felt like it could keep going, but I wanted to do other things with it. The battery: Samsung ICR18650-26C. I don’t know what amps, but perhaps higher would draw more power and faster heat build-up. So… if you’re running too hot, use a lower amperage cell.
EDIT:
— 1st test was with weaker cell and I didn’t watch it continuously, hadn’t noticed it auto stepped down. But definitely on the weak cell it wasn’t getting too hot to handle. However…
I did another test with an LG LGABF1L1865, which is 4.875 mA. Yikes — NOW I definitely experience the same thing. It cut off at about 45 seconds and it was WAY too hot to handle. It cooled off fairly quickly, but seriously, you can’t leave your hand on that head for very long while it’s on turbo.
