[Review] Convoy M21K LHP73B 4000K: Great light cannon, you will not regret it!
This is the Convoy M21K, a “small” light cannon that will light up everything you want, this setup has the LHP73B 4000K with a 20A buck driver, USB-C charging and more!
• My opinion:
The M21K is a pretty useful, powerful and fun flashlight to have. I really recommend getting it with the LHP73B LED, I loved the 4000K tint! This flashlight is an absolute light cannon, it will light up everything pretty far with the 10A and 20A modes, even the normal modes are pretty bright. The moonlight is awesome for a light so big like this, very dim with similar brightness as other 1 lumen moonlights. I really doesn’t have much to dislike on this flashlight, I really just hope it had AUX lights, especially for finding it in the dark, this could easily be made as the flashlight already has LEDs on the button to indicate the charging state.
• Pros:
  • Super powerful (6000 to 8000 lumens)
  • LHP73B LED has an awesome nice tint
  • USB-C charging
  • Stainless-steel bezel by default
  • Great thermals
• Cons:
  • No battery level light indicator
  • No AUX light to find it in the dark
  • USB-C rubber cap gets in the way when trying to connect the cable
• Box contents
  • M21K
  • 21700 Battery (bought separately)
• Price
The M21K with LHP73B is currently priced at $34.12 in Convoy Official Website. The Amprius 50Q battery adds $6.01 to the order in the flashlight.
• Body and build quality
Colors/Material Options: The M21K is available in aluminum alloy with 4 anodizing colors: Black camo, Green camo, Blue camo (featured on this review) and standard black. This Blue camo is absolutely fantastic, the design is so cool!
Material: The main body is entirely made of an aluminum alloy, probably 6061-T6 or something similar, Convoy does not specify it.
Main body: It’s full of knurling and grooves, this makes the flashlight have a nice and grippy body, and have better temperature dissipation.
Threads: All body threads are squared, the tail cap threads are anodized, this means this light has mechanical lockout by untwisting the tail cap a little bit, the head ones are not anodized.
Clip: The flashlight doesn’t come with a clip, but a screw on clip can be installed on the holes on the tail cap.
Tail stand and rolling: The flashlight can both head and tail stand, it rolls a little, but the rolling is stopped by grooves on the head part.
AUX lights: The M21K has a red light in the button to indicate charging, but the light cannot be be used as an AUX to find the flashlight in the dark or other uses.
Buttons: It has a single e-switch to operate the flashlight, covered by a black rubber cap.
Battery contact: Contact is made with the battery by a flat button on the driver and a thick nickel plated spring on the tail, to support the 20A maximum current this light is rated.
Bezel: The bezel is made of stainless-steel and easily removable by unscrewing it to access the LED.
Water Resistance: The flashlight does not have an IP rating, but I consider most Convoy flashlight IP68. The M21K for example has O-rings on all threads including the lens and bezel.
Size Comparison: On the left is the Convoy M21A, on the middle the M21K and the FireFlies X4 Stellar on the right.
• Weight and size
Weight:
  • M21K with battery: 284.5g
  • M21K no battery: 215.1g
  • Battery (Amprius 50Q): 69.4g
Size: 55.1mm (head diameter) / 31.0mm (tail diameter) x 141.7mm (height)
• Battery, runtime, and charging
Battery: The M21K is powered by a single 21700 cell, it must have at least 20A CDR, it only accepts flat top batteries, button tops doesn’t fit inside the battery tube. Simon was kind and sent an Amprius 50Q for review with the flashlight, this is a tabless cell, so it has lower internal resistance and a longer lifespan than traditional tab cells.
Battery Indicator: You can access the voltage check by clicking 5 times the main button, the main light will blink and show the voltage. Unfortunately the red/green light on the button cannot be used as a battery indicator.
Charging: The flashlight has USB-C charging on the main body, it is protected by a rubber cover. Used USB-C cables with a thin connector, because the rubber cap can be on the way sometimes. The red light will turn ON while the battery is charging, when it’s fully charged the light will be green.
• Modes, Runtimes, Throw, Candela:
Modes: The flashlight comes by default on the smooth ramping mode, where only moonlight, turbo 10A and turbo 20A are pre-set modes, by clicking 6 times on the main button you can go to stepped mode, where you have 4 pre-set modes to cycle from. I don’t have the measurements for the exact lumen count of the modes, but comparing to other flashlights the first mode seems about 50 lumens, second mode around 500, third mode around 1000 and the fourth mode around 2000-3000.
Turbo: This flashlight has two turbo modes, the 10A mode is on the 4 modes cycle, and can also be accessed by double clicking the flashlight, it’s very bright and actually takes some minutes to start heating up, and lasts around 2 minutes with around 2000-3000 lumens before a major stepdown. The 20A turbo is even brighter, Simon says theoretically it has 6000 to 8000 lumens of the LHP73B rated, but it gets hot REALLY fast, in just a few seconds you can fell the head becoming warm, that’s why this mode is only acessible momentairly.
Moonlight: Moonlight is actually pretty good on a big flashlight like this, usually these big powerful ones have a super bright moonlight, but this one is similar to the 1 lumen moonlights of my other flashlights.
Blinkies: This light features “Strobe” mode by triple clicking the main button.
Throw: This flashlight has amazing throw while also having a large hotspot, this is due to the amount of lumens it push + the 3° TIR lens, I’ve tested it to throw at least 400-500m but couldn’t get good beamshots of it.
• Emitter, reflector and CRI:
Emitter: This M21K setup has the LHP73B LED, the SFT-90 LED is also available, the emitter is way better than I expected, the tint is awesome! It’s very creamy and has some rosyness to it, loved it. It is a pretty floody LED, but with the 3° TIR lens it throw a lot.
Reflector/TIR: The M21K comes with a big 3° TIR.
Lens: There is a hardened AR (anti-reflexive) coated glass lens in front of the TIR.
Beam profile: The beam has a very concentrated hotspot, but still manages to have a lot of flood on the higher brightness settings, it has some artifacts if you go wall hunting. Picture taken at 2m away from the wall with 18mm lens
CRI: The LHP73B is standard 70 CRI as far as I know, but the color looks so good on this 4000K emitter that I belive it may have slightly better CRI and R9 levels than most emitters.
• Beamshots Camera settings:
  • 18mm lens 1" F8 ISO800
  • (The trees at the back are at a distance of around 100m)
M21K LHP73B 4000K - 20A Turbo**
M21K LHP73B 4000K - 10A Turbo**
M21K LHP73B 4000K - 4th mode (“high”)**
I always try to match what my eyes can see on the beamshots, so camera settings may vary.
• Driver and UI
Driver: It uses a 20A Buck constant current driver, so you have around 60W of power on this little monster! The driver is pretty good, has powerful brightness modes and also a very good moonlight.
UI: The UI is pretty simple. A single click on the button turns it ON/OFF, double click goes to turbo, double click + hold goes to 20A turbo. Holding the button while ON will change brightness. Triple click goes to strobe. Quadruple click activates tactical mode (you can only access 20A turbo momentairely. Quintuple click goes to battery check. 6 clicks change between the smooth ramp brightness and stepped brightness.
Low Voltage Warning: When the battery voltage is too low, the flashlight main light will start blinking and the red button LED will turn ON.
Reverse Polarity Protection: The flashlight is protected against inserting the battery with the wrong polarity.
Temperature Control: This is a big flashlight with big heat dissipators, so it will sustain the higher modes for a better amount of time than most flashlights, except for the 20A mode thant will heat up fast like crazy. It has temperature control, so when the driver hits 55°C the light will start to dim down to prevent driver and LED damage.
Lockout: This flashlight features eletronic and mechanical lockout (by unscrewing the tail cap a little). To access eletronic lockout you must press the main button 10x, the main light will blink to indicate.
A special thanks to Simon and Convoy for sending this flashlight for me to review!
*I am not being paid to do this review, everything here is my honest opinion.
Thank you for reading my review <3
6 Thanks
