Review: Convoy M3
hi,
these cells are PROTECTED?
thanks for info
It depends on the seller if they add protection circuit or not.
Hi
Can I use a Samsung 40T 21700 Battery in the M3?
I use this battery for the s21a and tried it in the m3 for a while and it worked
Is this safe to do?
Thanks
Sure, as long as it physically fits. Boost driver lights like this one benefit from strong batteries that don’t have a lot of voltage sag under load.
Thanks Jason for the quick reply!
Time to order some from 18650.uk :smiley:
Really nice and detailed oriented review.
Hi
Might change my mind and get a 26650 after all lol
This one is longer than normal ones, do you think it will fit in the m3?
https://18650.uk/product/keepower-26650-5200mah/
Thanks!
It will fit. Mine has plenty of spring and allows a 21700 to fit.
That is a very old battery and has a lot of voltage sag. There are much better on the market.
Thanks for the response
I want to get the shockli but they Are a little bit expensive!
Are any of these good?
https://18650.uk/product/ijoy-26650-battery/
https://18650.uk/product/efest-26650-battery/
That iJoy is pretty good, but the 40T and Molicel 4200 are better.
Great thanks again for your help!
Thanks!
I just received mine in the mail (5000k XHP70) and it only seems to have three modes, no moonlight, and no two click turbo from off. Has anyone seen this before? When I double click from off it just flashes once on low level and stays off.
This is normal behavior.
There is no moonlight, just low. (4 levels total including turbo)
Turbo needs a really good battery to work.
I use a black liitokala 50A, and most of the time i cant get turbo.
This is due to the boost driver requiring a lot of Amps from the battery.
This flashlight is in desperate need of a better driver.
Like all boost driver lights, low resistance is key. Make sure your battery ends, battery tube ends and spring ends are all clean. Make sure the driver retaining ring is tight. Use a high drain cell. LiitoKala 5000 should be pretty good, but Aspire 4300, Golisi 4300, iJoy 4200, etc… might be the better choice. Definitely no protected cells.
What is your complaint about the driver? Is it too powerful?
I am using EBL 5000mah, I thought i read somewhere that they’re over 20a but I can’t seem to find it.
The red and silver?
I can’t find any decent reviews and all the pictures I see show it as a protected cell. If yours is protected, that is the problem.
I believe that’s the one. I’ll just get some good cells and keep those in my go-bag. I try to keep cheaper cells in it since it stays in my car and sees temperatures between 0f in the winter and 100f in the summer
