Copy of DQG AA provided courtesy of www.cnqualitygoods.com
Specs:
- Emitter: CREE XP-E R4 4B CW / R2 4C NW
- Color Temperature: CW---6000K ; NW---4500K
- Material: High Quality Stainless Steel
- Mode: Lo>Hi without memory ; Twisty on/off
- Battery: 1x AA primary or 1x 14500 Lion ; No battery rattle
- Runtime: about 60 minutes on 600mAh 14500
- Current Regulation
- 0.5A on HI with 14500 lion; 0.3A on Hi at AA
- Size:16.5mm*17.5mm*72mm
- Weight: 32g
Well, actually the specs tells it all. I'll provide some more measurements.
The driver has no memory and always starts on low. Twist it off and on again and you get into high.
On a reflected ceiling bounce, i am getting about 140 lumens OTF on 14500. Surprisingly on a fresh Alkaline I am getting about 125 lumens OTF. The SA1 does 190 lumens from the ceiling bounce.
14500 - High current is 0.6A, low current is 0.026A.
Alkaline - High current starts off at 2.2A, cut slowly dwindles due to sag. Low is 0.032A. The low output on Alkaline is about 34% lower than on 14500, as measured on the lux meter.
It also nets me 0.032A with NiMH. Hence we can calculate that it gets approx 84hrs of runtime in low on a NiMH.
Absolutely no PWM is detectable, driver is current regulated.
Front of the light there is a GITD strip behind the TIR lens. Nice effect.
GITD for the back.
Driver is protected by a compressible rubber disc. Absolutely no battery shake or rattle in all directions.
Light can work with Trustfire Flames 14500 protected, no issue with the longer length. Also works with regular Alkalines. However flat top like the Bestinone.net 14500 IMR does not work. You need the cell nipple. It's not advisable to remove the rubber disc
Left is iTP A1 EOS @ 1.8 lm low mode. Right is DQG in low mode with a 14500. That's low!!! And it gets 35% lower with an Alkaline. BTW, mine is NW copy.
Beam quality is very nice. It's actually better than a XP-G or XM-L in OP. This is due to the TIR lens. No rings or artifacts.
I have both the CW and NW tint versions. NW is needless to say for the NW fans, it is not a 3 series tint and colour temperature is probably in the 4200k range. The biggest surprise is the CW, it is very pleasant to look at, no hint of blue. It's like creamy soft cold white. In low there is definitely not a single hint of green tint and the tint still looks great. This is very important.
Stuff like Sunwayman V10A goes low, but in the low-end the tint is absolutely horribly green. Shine it on a person's face and it's so ghastly. You don't notice this until you do a comparison.
Left is DQG cool white, right is Sunwayman V10A cool white with green tint. (it looks worse than that in real life)
I put in an exhausted zinc carbon AA and it still works dimly, so this is able to dig and use up all the energy in your AA cells until moonlight mode.
